Recommended Fuel Pump
Car: 1992 Camaro Z-28
Engine: 355
Transmission: Custom 700-R4
Axle/Gears: Stock 4th gen
My 255 lph in-tank pump finally went out. What are you guys using? I was thinking of running a sump, but there are no bolt in tanks set up for sump, and no welder in the world is going to modify my existing tank with one of those kits.
1992 355 Procharged ~ +600 hp
Thanks,
Jamie
Thanks,
Jamie
Car: 1987 IROC Z28
Transmission: TKO 600
Axle/Gears: 3.45 (G92 package)
Re: Recommended Fuel Pump
Thanks,
Jamie
Thanks,
Jamie
Engine: 355
Ya, I had the Walbro intank pump. It lasted about 15 years, but I'm trying to get rid of the in tank pump.
Has anyone tried modifying the stock fuel assembly to increase the pickup tube to 5/8 and run an in-line pump externally? I emailed the guys at Aeromotive with the same question, but they didn't respond with a definite answer. I'd hate to spend money and time if someone has tried this and knows it won't work.
Car: 1987 IROC Z28
My friend runs an external fuel pump but his is a carb setup. He's not on this site unfortunately.
