Radiators
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Radiators
I am going to replace my radiatior, so I was wondering if you could give me some brands and prices. I want an aluminum radiatior, if you have websites, could you list those as well.
Godti
'89 Trans Am (Red)
305 TBI 5spd
Godti
'89 Trans Am (Red)
305 TBI 5spd
1 Post
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Be cools are about the best money can buy,but they are expensive.I think they go for about $500-$550.Griffin and Howe also make good radiators.
Car: 88 Firebird WS6
The Griffin 31"x19" NASCAR GM universal radiator is somewhere around $190. You might have to do some minor mods (Aftermarket tranny cooler, adapting that 3/4" heater hose to go somewhere else, minor trimming...) But 2 rows of 1" tubes in an aluminum radiator for less than $200 kicks a?? and an aftermarket tranny cooler is a better idea anyway.
I got mine from CarQuest. It is made by Milodon, cost $180. Just like original except it is an aluminum core. They had to special order it.
--Steve S--
1984 Trans Am 305 LG4, 5 speed
RPO codes point to Recaro version
Daily Driver, Flowmaster 80 Series
--Steve S--
Like the above post said, the Griffin is a nice piece but definately NOT a bolt in part. There is a lot of modification that has to be done.
BeCool on the other hand DOES just drop right in. I actually returned my Griffin to by a BeCool.
1991 Formula w/ K&N filter running 11's. MAN THAT IS SOME FILTER!
Check this thread. https://www.thirdgen.org/messgboard/...ML/003030.html
and try here:
www.radiatorinfo.com
Good luck.
and try here:
Good luck.
Car: Transformed 86 Coupe
Engine: 400 sbc
I used the Griffin also, but I got the one with the 2 rows of 1-1/4" tubes. I also had them install a tranny cooler(I still use an external tranny cooler too). It cost me $333 and it fit pretty good. About all I had to modify was the bottom tray that the radiator sits in.
I had carpartsonsale.com order it for me.
IMO, anyone that spends $500+ on a radiator is on crack...Be Cool, not broke!
I bought a brand new AC Delco factory replacement 350 radiator for $200 delivered to my door.
'92 RS, ZZ4 10:1 350, Edelbrock 6085 heads, Crane 208/214 467/482 cam, GM/LT4 1.6 roller rockers, Edelbrock Hi-Flow base, runners & 52mm TB, SLP/Jet-Hot 1-5/8" headers, Catco 3" cat, Flowmaster 3" catback, Hughes 2500 stall converter, stock 700R4, Auburn Pro posi w/3.42, 17x9" SS rims w/BFG tires, Medium Quasar Blue w/white SS stripes, 48,000 miles....
