Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Walker Intermediate Pipe 46669
Old 03-20-2018, 08:33 AM
irvan's Avatar
Car: 1989 IROC Z28
I had a rotted out exhaust pipe from the cat back to the muffler. Ordered a Walker 46669 pipe and my mechanic who installed it said was easy to install and everything fit just as it should.
Old 03-20-2018, 12:15 PM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
Re: Walker Intermediate Pipe 46669
What was the OD? I think this is supposed to be 2.75" but is usually advertised as 2.5." When I bought one many years ago, it was 2.75.
Old 03-20-2018, 12:37 PM
Go Blue's Avatar
They're still 2.5" pipes. Walker doesn't make 3" or I would have already bought from them as they're cheaply priced.
Old 03-20-2018, 12:43 PM
turd_gen's Avatar
Car: 1985 Trans Am
Walker does have intermediate pipes in 3", but they're made for 4th gen cars. I used them for my exhaust and the fitment was good, just had to massage the hanger with a BFH. Part numbers are 53061 & 54064.
Old 03-20-2018, 12:52 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
I used a walker 2.25” to replace my 91’s rusty pipe and also for a rear turbo system. Worked great
Old 03-20-2018, 01:04 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Old 03-20-2018, 02:44 PM
Drew's Avatar
Received 1,052 Likes on 748 Posts
The confusion comes from the size of pipe GM used. Walker's 46669 is a nearly exact copy of the factory high output 3" exhaust pipe. Just like the OE part, it's mandrel bent and about 2.75" in diameter, and like the factory pipe it necks down to 2.5" diameter when it enters the muffler. So then do you consider it a 3" pipe because a quarter of an inch is insignificant? Or a 2.75" pipe? Or do you advertise it as 2.5" because thats the size that slips into the muffler for the last 3"?
Nothing wrong with the 46669 aside from most aftermarket thirdgen style mufflers are a true 3" inlet. That and the 46669 was not available for awhile... For that matter, the Walker 2-piece 3" intermediate pipe they offer for fourth gens is hard to come by too.
Old 03-20-2018, 03:07 PM
irvan's Avatar
Car: 1989 IROC Z28
I had a hard time finding the pipe and was glad to get it, I have a Dynamax muffler that was put on the car right before I bought it and am amazed they didn't replace the leaky pipe while at it. The car is much improved with the new pipe. Thanks Drew for the technical assist on the description.
Old 05-16-2018, 06:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sounds like the L69 intermediate pipe that I once swapped into my car—huge compared to the LG4 pipe.
JamesC
Old 05-16-2018, 09:19 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Interesting Drew. I passed on that pipe a couple of times because I assumed it was a 2.5" pipe.
Just an aside, the low po factory 2.25" IP necks UP to 2.5" to slip onto the muffler.
Old 05-16-2018, 10:28 AM
naf
naf's Avatar
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
JamesC
the walker replacement I pipe for the L69 was 2.5" all the way. At least the one I put on my Pontiac several years ago was. It has the four bolt flange for the cat. Probably of questionable sustainment these days as the four-bolt cat is likely to become a hard to find item...BUT if you have the L69 y-pipe and want to keep it, that's probably your only option.
The fourth gen two-piece I pipe was 3" all the way. I installed it with a magnaflow 3" input muffler. Only had to readjust the hanger location slightly with an additional hole on the frame rail. It has a slip fit connection to the cat instead of the later thirdgen two-bolt ball socket fitting as shown in the photo above.
Old 05-16-2018, 11:51 AM
JamesC's Avatar
The aftermarket catback I initially swapped into the LG4 system was 2.5, which, of course, was larger than stock. The OE L69 system was 2.75—larger than the above aftermarket catback. L69 Y-pipe below for the sake of comparison with the LG4.
JamesC
Attached Thumbnails Walker Intermediate Pipe 46669-screen-shot-2018-05
Old 05-16-2018, 12:25 PM
chazman's Avatar
Axle/Gears: BW 3.45
The 4 bolt flange is also on the '85 TPIs. The '85 LB9 was essentially an L69 with a TPI intake.
Old 05-16-2018, 04:30 PM
Drew's Avatar
It's crazy how many variations GM went through on thirdgen exhaust. From the dual resonator Silly-Straw system early on, to the wide mouth converters, TOTL V6 systems, single 3" cat setups, and two different dual cat setups... Then things got really goofy with the fourth gens before coming back to a single 3" exhaust that mirrors the 92 dual cat system.
The aftermarket has had to deal with producing parts that address as many configurations as possible. Walker did their best to interchange with stock, meaning you can take a single pipe out of the stock system and replace it with a Walker part and it'll bolt right in. Other companies offered one crossflow muffler and tail pipes to replace everything from the V6 to the 350 V8. Then you've got the aftermarket performance systems that use a true 3" pipe, or smaller pipes to mate with the LG4 or V6 converter... It's a wonder any of these parts work together at all.
Old 05-16-2018, 05:14 PM
irvan's Avatar
Car: 1989 IROC Z28
And that's why i was really happy that it all fit like it was supposed to.
Old 02-13-2020, 03:40 PM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
Short question on an older Thread: Will the Walker 46669 fit my 92 5.0 TPI with single cat setup? I have a local offer fot that pipe. I know it would fit on my Magnaflow muffler, only question is, will it fit on the original cat converter? I have the Walker 15735 cat and it fits my Walker 47638 intermediate pipe, but it is old and I need a replacement.
Old 02-13-2020, 09:44 PM
Drew's Avatar
It's technically for single ~3" cats. It won't fit dual cats without mods, and the inlet may be too large for the smaller single cats. 92 tpi with a single should be the tiny 305 cat. 50/50 chance.
Old 01-09-2021, 10:19 PM
tglennon11's Avatar
Car: 87 IROC
Axle/Gears: LS1 10bolt w/ 3.73
so i just found this thread- sorry im late- Ha. I run the AP X5500 I Pipe, works great. I had to have the front end opened up a bit to slip fit my 3" test pipe inside the front end, and then had to move the bracket a bit to hit the original mount on the pass side.
see post #70 in this thread-
https://www.thirdgen.org/forums/exha...catback-2.html
91banditt2
01-23-2020 06:41 PM
Colt
10-18-2017 02:05 PM
Ramon Duvernay
11-07-2016 11:09 AM
86 Camaro joe
12-08-2010 01:17 PM
kairles
07-10-2004 11:04 PM
Quick Reply: Walker Intermediate Pipe 46669
