Any aftermarket oil pressure gauge for 92 camaro?
Hi, everyone.
I'm looking for an aftermarket oil pressure gauge for 1992 Camaro, hopefully more accurate one than a stock one. Is there any aftermarket one available specifically for 1992 models? Or do I need to use a universal one?
Also, when installing, I think I have to leave the stock oil pressure sending unit as it is because it has functions more than just sending oil pressure signals to the stock gauge. Any information around this will also be welcome.
Thank you.
JunJun
Thank you.
JunJun
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Re: Any aftermarket oil pressure gauge for 92 camaro?
I have Autometer Mechanical Oil Pressure and Water Temp gauges in my '92. Some don't like mechanical as they are a little more work to run the tube/capillary lines, but I trust them much more than the electric gauges and senders.
I've had many a panic in the past because of an incorrect reading on the electrical gauges, both factory and aftermarket.
...That being said, there are lots of electric gauges to choose from as well, if that's your preference. Did you want something to fit in the dash or mount somewhere else in addition to the factory gauges?
-Rich
-Rich
Abubaca
07-18-2010 06:22 PM
