Aftermarket Vendor Review Provide questions and comments about aftermarket part vendors for the Third Gen F-Body.
BIG BRAKE UPGRADE
Old 06-01-2006, 10:33 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
BIG BRAKE UPGRADE
Just got my brakes from Scott down over there and I LOVE THEM!!! What a great guy to do busniess with!! I recommend him if your planing on doing this upgrade.
bigbrakeupgrade.com
See for yourself
Joey
Old 06-01-2006, 11:54 AM
Twisted92Z28's Avatar
Car: 1992 Z28
Engine: 5.7L 350 TPI
Thanks for the info, im looking to upgrade my brakes and did not know about these guys.
Old 06-01-2006, 03:44 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Im also looking in to it. Im not sure if I should do the LS1 upgrade or the C5 upgrade.
Old 06-01-2006, 08:10 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Whatever you get it will be top quality!!! Get them, its well worth it Belive me
Attached Thumbnails BIG BRAKE UPGRADE-img_0021.jpg   BIG BRAKE UPGRADE-img_0019.jpg
Old 06-06-2006, 05:06 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Hot damn! Mine are in the mail as we speak. I've only waited 3 years to finally get big brakes. Good to know we're dealing with good people.
Old 06-06-2006, 11:54 PM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
There is also a Board Sponsor named ebmiller who sells brakes. In case you didn't know.
Old 06-07-2006, 12:04 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Ebmiller is great as well. However, I got my brakes from them almost two years ago when he only did ebay ads and they still work fine. Also go ahead and get new hoses while you are at it.
Old 06-07-2006, 12:38 AM
Car: 1992 Z28
any suggestions as far as hoses go
Old 06-07-2006, 10:31 AM
Car: 91 Camaro RS
I went with basic advanced replacement hoses, because the insides of mine had deteriorated into a one-way valve. You could get braided if you have the money.
Old 06-10-2006, 09:47 AM
honkeytonk_man's Avatar
Car: 1988 IROC-Z
Engine: e-tec headed ZZ-4 350
Transmission: t56
Axle/Gears: 9 bolt 3.7 posi
Big Brake Upgrade Excellent
I just completed the c5 upgrade on my Z-28 and am very pleased with the results. This upgrade represents a great value, the quality of parts and assembly seemed very good and the package represents a very good value in a upgrade that literally drops on (20 min a side max). Best of all is the performance increase: The old 10.5" set up (which had all new componets five years ago and fresh pads at the time of testing) was just lousy. In testing with a G-tech best 60-0 for the 10.5 setup was 146 feet, with the C5 setup it was 121 feet. With the 10.5 setup I could not lock up the brakes with the pads cold (run number one), run number two was best however the brakes were still hard to modulate. All subsequent runs sucked, with signifigant brake fade, hard to manipulate 'grabby' brakes, unexpected lockup and smoking brakes eventually! The c-5 setup just felt good, was easy to manipulate hot or cold, with consistant lockup right at 5mph, was extremely fade resistant and offered solid performance regardless of tempreture (all stops were between 121-126 feet, pretty good with my less than track worthy technique). So all in all very pleased great bang for the buck upgrade!
Old 06-10-2006, 12:23 PM
Camaroz29's Avatar
I also went with their C5 kit and couldn't be happier. Link:
https://www.thirdgen.org/forums/brak...-complete.html
Old 06-11-2006, 10:00 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Glad to hear that you guys had good luck with the upgrade. I bought some Hubs and Brackets from TPI383 (aka Chris Eckard) here on the board. Had to wait over 6 months for some rusty S10 hubs with a crappy slapped on powder coat finish and they even had ABS rings still on them. what an A@@hole. Then he tried to feed me some BS about this guys fault and that guys fault and being sooo busy. Blah Blah blah. Stay away from him!!!!
Old 06-21-2006, 08:42 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Did you get to install them yet? How has your braking improved? Im going to be buying the LS1 upgrade in a week or so. I know the C5 kit is only a little more but I dont have it in my budget to get new wheels tio fit the C5 kit.
Old 06-21-2006, 09:32 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Let's talk turkey.
Is the "BIG BRAKE UPGRADE" a direct bolt in replacement for my front brakes?
Will they work with my GTA rims?
What other parts should I get with this upgrade?
How much can I expect to pay all told?
A Dutchman wants to know...
Old 06-21-2006, 09:58 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Originally Posted by Cadillac
Let's talk turkey.
YES MR. Dutchman, its a bolt on, He ships it already assembled and ready to slap on. Im not sure if the GTA rims will work, i know that if its a 16" rim i think you will be fine. Everything ran me about 1K but i also got the rear rotors as well, with slots or course. Rather do it right then kick myself later on. You also want to get the earls brake lines. Mine where all beat up so why not. This isnt really a cheap bolt on, but im sure it will increase stoping power and for sure looks.
Old 06-21-2006, 10:33 PM
Car: 91 Camaro RS
My front setup cost me $519 to my door a year ago. With new ball joints, hoses, and fluid, somewhere close to $600. But I got regular rotor and some decent $~40 set of pads.
Old 06-21-2006, 10:38 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
I did the whole works LOL.
Old 06-21-2006, 11:11 PM
Cadillac's Avatar
OK... Work with me here. The BBU site is kinda slack on details.
Here's the scenario. I have all stock stuff with 16 inch front and rear GTA style rims with drums on a non-posi rear 2.73 rear axle. If I make this order I can expect something that will replace what I currently have on my spindles in the front? Obviously I would love to replace with the rear axle with a 3.27/3.23 with disks and that would help but focusing on the fronts, would this be a adequate?
Old 06-21-2006, 11:23 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
The fronts Get replaced with all new stuff. Spindles, brakes, brake Lines(Option) Rotors(cross drilled Option) Calipers(poweder coated Option) Everyting is new. About your Rims, thats somthing that you will have to ask Scott. Does this make a little better to understand bro?? BBU does not sell anything for the rear. only fronts.
Old 06-21-2006, 11:39 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
I am interested in this, but how can unbolting all my old stuff and bolting on this kit really only take 20 minutes per side?
Old 06-21-2006, 11:41 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
cant really tell you cause i havent done it yet. Almost there though. But it all comes together for you shiped. Just unbolt old stuff and insert new. Bleeding the brakes may take a little long, Just make sure you have a buddy helping you.
Old 06-22-2006, 01:00 AM
Cadillac's Avatar
Thanks, Joe.
Old 06-22-2006, 10:49 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Thanks, Joe.
OH FO SHO!!!! LOL
Old 06-22-2006, 11:46 AM
Camaroz29's Avatar
Becuase it is like he said, the kit comes fully assembled. The pita part is bleeding the brakes when you are done.
Old 06-23-2006, 07:22 AM
Bull's Avatar
Engine: LT1; None
Well, then I need one of you guys to come over to my place to do the swap. I'll have the kit waiting for you, and I'll pay you $100 per hour to do the job.
I read the instructions on the site, and you have to compress the spring, disconnect tie rod etc. I guess I am just real slow and a scaredy cat around compressed potential energy in a spring, because it'd take me waay longer to do the job.
It does look like an awesome kit on the website, though, and I have put it on my "future projects" list.
Old 06-23-2006, 10:31 AM
Cadillac's Avatar
Ditto. My list is getting large. I love that.
Old 06-23-2006, 11:29 AM
Bull's Avatar
Engine: LT1; None
Mine, too. Is your wallet getting larger as well? Mine seems to be getting thinner
Old 06-23-2006, 02:02 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Looks like a solid product. Gonna order a set
Just out of curiosity, how are you guys handling the m-cyl.? I have PBRs in the rear and the brake pedal with the stock 'FX' one goes nearly straight to the floor.
Old 06-23-2006, 03:40 PM
Car: 91 Camaro RS
I have pbrs rears and ls1 fronts and my master feels good. I'm still using the original master and small disc/ drum prop valve. Eventually I'm going with the 1le prop, ls1 master, and ls1 resevior.
Old 06-23-2006, 04:34 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The caliper will hit the crosslaced center section of the GTA wheels. You will need a thin spacer to use LS1 brakes with GTA wheels.
On my home computer, I have a bookmarked thread containing information on the thickness needed. I'll try to look it up when I get home from work. I believe the spacer was a stock GM part.
Otherwise, talk to Mike at bigbrakeupgrade.com or PM ebmiller for the specifics of the spacer's width.
I plan on doing either the 1LE or LS1 brake upgrade by the end of this summer hopefully.
Old 06-23-2006, 07:57 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
Let's talk turkey.
the 12" front C4/C5 NON hd LS1 will fit under mesh wheels. the 13" nope sorry. I am in the same boat.
Old 06-23-2006, 08:35 PM
Jade Grey's Avatar
Engine: 305TPI
Here's the thread I remembered, edmiller and brake gurus come in.
The spacer was used on the later GTA and formula wheels on rear drum axles. The part number is 14091902. It's only .030" thick. Being that thin you may be able to use washers instead.
Old 06-23-2006, 11:41 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Sorry but I wouldn't use just washers, the wheel needs to be snugged down on more than just a set of washers. It's all about surface area and torque...be safe fellas.
Ed
Old 07-07-2006, 07:49 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
LS1 kit
Just ordered the LS1 big brake upgrade kit. I got it with hawks pads, drilled and slotted rotors and earls brake lines. I cant wait to get it.
Old 07-07-2006, 08:35 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Your going to love them. I got what you got. I put them on already and man, it was easy. Took about 1hr for both sides and about 30min to bleed the brakes.
Old 07-13-2006, 11:02 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Just got the LS1 kit. What an awsome set up and it came fully assembled. I cant wait to put it on.
Old 08-10-2006, 06:22 PM
Cadillac's Avatar
What an awesome thread.
(not so subtle bump)
Old 08-13-2006, 07:44 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
But dont they make the wheels stick out farther? Im Thinking of doing this as well but want to keep my stock rims.
Old 08-13-2006, 02:02 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
They should, but it's only the thickness of the center portion of the rotors which from what I hear is only .300 of an inch.
Tom
Old 08-25-2006, 10:50 AM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
I completed the LS1 upgrade on my Z28 about three weeks ago. Now I have outstanding brakes and the parts Scott uses are quality components. I already had Earl's Hyperflex brake lines on my car which interchange to the LS1 kit and you won't go wrong using the Speed Bleeders. I never tried them before but will install them on everything I own now they just work. GREAT UPGRADE Thanks Scott
Old 08-25-2006, 11:04 AM
86Z
86Z's Avatar
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i just recently got my front ls1 kit from scott also with the slotted and drilled rotors and the earl ss lines, these things look bad, i cant wait till i install them, very nice setup. i may purchase another set just to sit on my shelf
Old 08-31-2006, 05:15 PM
  #42
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Did anyone have a problem with the Earl's lines from big brake upgrade? There is no fitting on the new lines to secure the line to the braket on the strut.
Old 09-01-2006, 03:02 PM
  #43
ebmiller88's Avatar
Yes:
https://www.thirdgen.org/forums/brak...lled-earl.html
Ed
Old 09-01-2006, 06:45 PM
  #44
systalis's Avatar
Car: 92 RS
Engine: Built 355
Transmission: Built 700r4
Axle/Gears: 3.73's w/ stock axles
I just stumbled on this thread today. I also got a complete front and rear disc from scott about 8 months ago. I spoke with him on the phone several times before my purchase and he is a really nice guy. He also e-mailed me a few months after my purchase to see if things went smoothly. The system came in three or four boxes and was expertly packed. I would recomend big brake upgrade to anyone who askes.
Old 09-01-2006, 08:58 PM
  #45
yuel's Avatar
Car: 91 z28
Transmission: 4l60
I dealt with scott about 6 months ago, great guy and answered my questions. I took the brakes parts from him and upgraded to c6 brakes.
Old 09-01-2006, 09:08 PM
  #46
Has anybody had a problem with the abutment spacing and pressing against the rotor. I was installing the abutment on my C5 kit when they tightened up against the rotor binding it up. I had to use a 1/8" thick harde ned spacer to some what correct the problem. I am however using Baer modified spindles and Baer aluminum hubs instead of modify the factory stuff. I compared some factory hubs to the Baers and they look the same. I am not so sure about the spindles though. Anyone have experience with both??
Old 09-02-2006, 07:16 PM
  #47
ebmiller88's Avatar
Why doen't the guy at BBU reply to these questions???
This may happen due to casting tolerances in the spindles, I have experience with this. For example, some spindles may need a 3/8" bracket, some a 1/2" bracket for the same brakes. Using a spacer washer is just fine and won't cause you any issues IF installed properly. Always use red threadlocker on the carrier bolts and tighten them down good and tight, and let the locker cure properly.
Also, since you're using Baer hubs, they may be just a hair off in location and causing this issue. Again, not a biggie, just use the washer and go. Any slight misalignment will be taken up by the sliding of the caliper and by pad wear.
The spindles are Baer units but are close to 1LE castings.
Ed
Orr89RocZ
04-25-2016 08:28 AM
Adamki2000
Brakes
24
12-20-2015 10:40 PM
lt1z350
08-28-2015 05:57 AM
zayne0
08-24-2015 07:22 PM
MustangEater82
Brakes
08-11-2015 07:52 AM
Quick Reply: BIG BRAKE UPGRADE
