Mishimoto Alum. Rad
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Mishimoto Alum. Rad
Decided to pull the trigger and pick up a Mishimoto alum. rad off ebay. Install coming soon but looks like a quality piece.
http://www.ebay.ca/itm/370849850487?...84.m1497.l2649
Came with a 19lb rad cap and is just over 2 1/4" wide (see pic).
Car: 88 Camaro Sport Coupe
Engine: 305 TBI
Re: Mishimoto Alum. Rad
I can't personally speak for their third Gen radiators but my little brother put one his 91 Eclipse turbo about 3 years ago and its never given any problems.
Car: 89 IROC
Install should be in 6-8 weeks. Need to make a plate to mount the 4th gen fans and run the custom rad hoses.
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
I don't think I would use a radiator cap with that much pressure. 19psi is really high and will more than likely cause a leak somewhere in the cooling system. I usually use 10-15psi caps. It's less efficient but a lot safer.
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Hey, I was wondering if you have had the chance to try out the Radiator, I was thinking of ordering one and I was wonder how you like it. How does it fit and what not thanks.
Car: 89 IROC
Still working on the car so the rad has not been put in permanently.
I did a mock set up for clearance and positioning and it fitted fine.
No issues.
No issues.
Car: 86 Z28
Where did you get yours from? Are they set up with a Auto Tranny cooler? I would rather not have it in the Rad if I have a choice. IS it set up with all of the Right ports and everything?
Car: 89 IROC
Got mine on ebay.
You can order the auto trans cooler for additional charge. Personally I think the trans cooler they offer is a little steep price wise.
Car: 86 Z28
The Project can you check and see if A stock Rad cap will fit the Mishimoto Rad. I don't like the idea of a 19 Lbs Cap.
Thanks,
Tyler
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Two of those ports are for the built-in automatic transmission cooler. Then there is a 1/8" NPT port which is used for the factory coolant temperature sensor, and a 1/4" NPT port which is used for a coolant level indicator gauge. Please let me know if you have any other questions.
Thanks,
Tyler
Thanks,
Tyler
Car: 89 Camaro RS
Engine: 2.8 V6
Transmission: Automatic
Having the tranny cooler in the radiator is not a bad thing; on the cold days it helps get the fluid up to normal operating temperature; simply add an auxilary trans cooler in-line with it if needed; I generally setup the aux cooler to be the initial cooler. Easy enough to swap the lines around if needed during the summer months.
As for the radiator cap; I agree with it being a little on the large side. It will not help cool the engine, just be a little bit of an insurance policy once you cross 260* as hot water cools better than steam. But if the rest of the cooling system is up to the task is another story. I would probably go with a standard 16psi replacement cap
KITT1983,
Thanks for the reply!
The radiator you are referring to is assembled overseas. Please understand that all R&D is done in our facility in New Castle, Delaware. We have an extremely strict quality control program to the point that we have a created a separate Mishimoto workforce to check each and every unit before boxing and shipping. Additionally, we carry a second-to-none lifetime warranty against manufacturer's defect including accident protection!
Thanks,
-Pat
Thanks,
-Pat
We pride ourselves on offering an amazing lifetime warranty against any manufacturer's defects for the life of the product. In order to qualify for the warranty, you must purchase the radiator new from an authorized dealer and retain a copy of your receipt. For complete details regarding our warranty, please click the below link:
http://www.mishimoto.com/warranty-info.html
Let me know if you have any additional questions.
Thanks,
-Pat
Car: 1988 firebird WS6
Engine: 385 stroker
Transmission: Pro Built Street/Strip 700r4
Axle/Gears: 12 Bolt 3.73
What is the horsepower cooling capacity rating with and without electric fans?
Let me know if you have any additional questions!
Thanks!
-Pat
Engine: gone
Transmission: gone
Axle/Gears: gone
Well it don't look all that much different than my Silla all aluminum radiator but if i gotta change that radiator one more time then i may give these a try.
Car: 89 IROC
KITT1983,
Thanks,
-Pat
Thanks,
-Pat
Wish more vendors did this...
Engine: 385 stroker
Yup I just bought a mishimoto radiator too it looks the company backs up there products.
Thanks for all the replies everyone!
If the shroud came on the OEM radiator, you should have no problems swapping the shroud to the Mishimoto radiator. While I personally do not have 100% knowledge on F-bodies in general, I would imagine the stock mechanical fan will be compatible as that mounts to water pump/engine rather than the radiator. There should be enough clearance for the OEM mechanical fan to fit.
If anyone else has questions, feel free to ask!
Thanks,
-Pat
Thanks,
-Pat
1 Post
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
I have just purchased one of these units, and I'm really looking forward to when it arrives. I looked at other rads available, and I just couldn't swing the cash required for some units, and others just looked cheap. When I saw these being sold through summit racing, the quality and price just seemed right. I'll report back once it's installed.
I received my Mishimoto radiator over the holidays and installed it today (dry fit). Overall I love the quality of the radiator, the welds are superb.
Unfortunately I did run into some issues. Mainly that its not a direct fit. Ran into the same problem the guys did with the Champion radiator. The rubber mounts need to be shaved drastically to make it fit. To get the radiator to sit correctly under the shroud cover I had to completely remove the bottom rubber mounts. No ammount of shaving them would let the radiator sit properly. The uppers I was able to keep (I still need to modify them for a better fit though).
I didn't have enough time to see if the oem electric fan assembly bolts in though (fingers crossed that it will work).
And lastly as far as the ports on the radiator. My camaro has the coolant temp sensor in the intake manifold, not on the radiator. So, I had to go to the local parts store and buy a plug for that port.
Car: 88 IROC-Z / 92 z28
Engine: LB9 / sbc of a station wagon
Transmission: 700R4 / t5.6
Axle/Gears: i have 2 now!!
Lots of posts about installing such radiator, and no pictures! what a shame
Reason why Mishimoto? quality, warranty and proven worldwide. I ran into the same issues of the Champion radiator install. Regarding the fans, my car is a 1992 z28 which has dual fans; I had to space the fans 3/8in to have the same gap between the radiator and fan as the factory gap (not needed, but recomended).
Note: the fans were spaced at the bottom and top mounting supports
I also had to close one of the holes on the passenger side.
Regarding the radiator cap, yes you can use an original replacement cap.
and I upgraded that too
Car: 88 IROC Z
Engine: United Racing Engines 383 Stroker
Transmission: TKO 600
Axle/Gears: Moser 12 Bolt, 3.73
MFaust89, nice write up and pics.
I recently purchased and installed a Mishimoto radiator myself. I did have the same MINOR fitment issues listed above. Nothing a little bushing shaving and a couple of NPT plugs won't fix. So far the radiator has been awesome.
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
Does anyone know the tube size in the radiator? And how much of a difference did it make towards cooling?
#42
1 Post
Car: 1988 IROC
Transmission: 700R4 Silver Dart
Axle/Gears: 3.70 posi
Not sure on tube size but it kept my car around the 195-202 mark on a low 90's high humidity day this past July. This is after the motor was heat soaked. My car was running 10-15 degrees warmer before the swap. This is on stock dual fans. I have no complaints thus far. Been in the car a year.
#44
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Air flow, air flow, air flow.....
The more rows on the radiator the stronger the fan needs to be. Especially if there's a condenser in front of it.
That's why a stock radiator in good condition (fins not all bent over with good flow) can handle a decent amount of heat. It requires a large fan with a shroud incasing it.
That is a nice looking radiator.
