miniram fuel rails
Transmission: auto 700r4
Axle/Gears: 3.75
miniram fuel rails
I am looking for the difference between the f-bosy fuel rails, and the vette fuel rails for a tpi car.
On the tpis website the f-body is not pictured, so I was wondering if some of you know the difference, and if I can make them work on a vette.
the vette kit looks almost the same as the hsr fuel rails on the web sites, and like I could make them how I want, but I am not sure if the f-body are the same just set up different, or totally different all together.
Car: 92 GTA
Transmission: 5 Speed
Axle/Gears: 3.27 posi
Re: miniram fuel rails
i think its on which side the lines run. on my TA the fuel lines are on the drivers side. The mini ram fuel rails sit at angle and tighten up to the intake in order to keep the injectors seated. The rails are expensive but buying twice is more expensive. Just my opinion.
Axle/Gears: 3.75
Thanks, I'll see when I get it, but I think they weld up the ends of the fuel rails to make them tpis dedicated, and I hate it. I am also considering changing it, or some how using the stock fuel rails to make something before i pay their outrageous price for some fuel rails.
I believe the fuel rails are the same between the kits. It's the thermostat housing / water neck that is different. The vette water neck will not work on an FBody.
You could always call TPIS and ask if there are any other differences between the two.
1 Post
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
The only difference between the vette and F body fuel rail that I know of is the return and feed lines are nearly straight and short on the Vette fuel rails and the F body feed and return lines are longer and angled towards the driver side.
Axle/Gears: 3.75
Yep, that seems to be correct from the photos, and tpis.
Thanks for all the responses guy.
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
TP thanks for replying Ok so stock rails are out are there any A/M that will work or they TPIs only think that will fit? theit kits priced near $360 seems excessively high the Pro-flow XT is looking better all the time
