stealth ram alternative fuel rails?
#153
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Re: stealth ram alternative fuel rails?
What is wrong with a 30-70psi regulator?
-- Joe
-- Joe
#157
1 Post
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
My polished HSR showed up today. For what paid for it I guess i'm okay with it. It's pretty roughed up and i'm not pleased at all about the two bolts tapped into the passenger side of the plenum. The seller should have disclosed this. Oh well, after I give it a re-polish it should be fine.
SAM_1736_zps7fa3312c.jpg?t=1362017029
SAM_1735_zpsd4aea4a0.jpg?t=1362016939
SAM_1737_zps690742b6.jpg?t=1362017120
#159
1 Post
It would thave been nice if they were tapped level at least. My first thought was to have to aluminum IROC Z badges made and mount them on both sides but the holes are crooked.
#164
Okay guys. I got my Fuel Rails yesterday and my afpr a few days ago. But before I post up the picture, Here is a "printscreen" of my iPhone. When I bought the AFPR, I was conversating with the seller through Ebay. I said to this person "man", "bro", and "dude" over and over and over agian. To make a long story short, the seller replied with this........
#167
1 Post
Those rails do look really nice. Go get some shorter 1/4 inch stainless bolts to attach them.
#171
Oh man. I've been extremely busy. I won't say what I do other than I work at Target, work as a computer repair technician and I run my own business. So in other words, I forgot. But tomorrow for sure. I'll get them. So it's a 1/4 correct?
#172
1 Post
Yep. 1/4 inch for the rails and 3 short 1/4 inch bolts to attach your cable bracket to the plenum when your ready to install it.
#175
Ok. I got 4 - 1.5" stainless steel bolts. But there is one issue. The bolt holes don't line up perfectly. The machined holes are too close to each other and will not allow the bolts to go in smoothly. Is that a problem for some? Yes. Is it a problem for me? No. I have my dremel and a tiny carbide burr. So tomorrow, if I don't get my large tattoo finished on my back, then I'm gonna get the rails prepped for the bolts.
#185
Doesn't look like there is much room or the front of the rail for the fpr. I think your option for that would be do the crossover on the front , plug the rear of the passenger side and the return will come right off the bottom of the fpr.
#187
The coil I got is a MSD 8226.
#188
I think that's what your talking about, I'm not sure what an yo have on your return but you would need to but one more fitting.
http://www.summitracing.com/parts/fra-491970/overview/
#200
