Miniram - Thermally insulating fuel rails
So I started thinking about the fuel getting hot in these fuel rails. Particularly with no front crossover and the fuel essentially dead-heading on the front end of the rails (especially on the side without with the regulator) until the injectors consume the fuel.
What I did was buy some .060" thick PTFE washers and some fiberglass bolts from McMaster Carr. I put the washers between the rail and manifold as well as bolt them in with the fiberglass bolts. The hardware has a max operating temperature of 500°F, plus the bolts don't need a lot of torque on them since they're only there to keep the injectors seated. There is now no metal-to-metal contact between the rails and the manifold.
What I'm noticing is a better consistency in how the engine runs between when it's cold and when it's hot. After playing around with the MAT tables for a while and seemingly getting that optimized, I started thinking about the fuel.
Any rate, It's not a huge night and day difference since the car already runs well, but for someone picky like me, I can tell a difference.
When I get home after driving around for a while and the engine is at full operating temperature, I can literally put my hand on the rail indefinitely and and it's just a little above ambient underhood temperature (just a little warm). Where as the manifold itself, I can't keep my hand on it for more than a couple of seconds before it gets too hot to touch.
I'll probably go ahead and put in the front crossover on a little later to get the full effect of this thermal improvement. My guess is I won't see as much as an improvement since the rails are already pretty cool, but I"m still curious and it can't hurt.
What this helps prevent too is the fuel acting like a heatsink and carrying engine heat back to the fuel tank (thereby heating the fuel in the tank over time). Which may help explain the improvement being more noticeable the longer the drive is.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Re: Miniram - Thermally insulating fuel rails
Now I'm running one on my Formula using a Megasquirt. It still won't run the same day to day.
It's like a carb. I gotta start it, and let it warm up before I try to drive it. Doesn't seem to matter if I add or subtract fuel, play with ae, etc, when it's cold it's a turd. Once it's hot it's fine, but my wideband shows different AFR's from day to day and I can't correct it via IAT because my air temp is almost always consistent because of the blower.
The singleplane wasn't like that.
-- Joe
yeah, it's a fickle manifold... and YES, AE was an ENORMOUS challenge to get just right. But I've always loved how the torque curve felt in seat of the pants (not to mention how clean it looks under the hood), so I stuck with it (though I will admit there were times I thought about changing to some other manifold).
I've had to do some re-engineering on it to get it to run the way I want...
A few years ago I generated that separate idle air distribution manifold to avoid having the cylinders competing for air out of the main plenum at idle. That killed of the split BLM issue and smoothed out the idle tremendously (since I couldn't tailor the fuel per cylinder due to batch fire, figured I'd tailor the air instead).
Now, the fuel temperature seems to be making a difference (though again, more slight). I just got my AN fuel line and fittings the other day, so I'll probably generate my front fuel cross over in another week or so when I get the time.
It's funny how GM started the LT1 off in 1992-1993 without a front cross over and then promptly put one back in 1994. Not sure what the reason was for that, but it's curious that the TPI's always had them and then they tried to delete it, but then had to put it back... (unless it had to do with moving to sequential EFI in '94).
I don't think I'm boiling the fuel even at 40 psi. But thermodynamically it seems like it's better to have cooler fuel based on my results so far...
Engine: 4++,350 & 305 CIs
From what I've seen, generally speaking, a higher psi (to a point) also gives a finer, easier to burn fuel spray. Of course it does depend on inj type some as well.
-- Joe
Oh yeah, a lot of truth to that to. A lot of shortcomings with the MR intake/stock ecm on these cars.
The Corvette also has a hybrid MAF/MAP fuel blend.
I'm not willing to upgrade to an MS3 for sequential though.
I'll get it 'close enough' but it won't be perfect.
-- Joe
1 Post
Car: 91 Z-28
Engine: 420 sbc
Axle/Gears: 12 bolt/4.10 gears
I've had my miniram for 14 years and it has always ran well. It's got distribution problems at low rpms but the tune will solve most of it. I can start it up n drive it immediately with no issues. The only issue I have is the fuel getting hot. I've got my rails fed from the front with a y off the feed line with the stock regulator return setup. On a hot day it will lose 4 psi when it gets heat soaked every time. I still can't figure out if it's the excess flow or the exhaust heating up the fuel pump. I know my pressure loss is coming from the pump because I can hear it change pitch when it does this. Might just be the nature of the beast with a 255 pump in a return system
1 Post
Car: 91 Z-28
Engine: 420 sbc
It doesn't but I've worked around it to make my car every day driveable. I run open loop only because my particular engine hates stoic at anything other than very light throttle cruise. Normal cruise it likes 13.5-14. Mild to heavy acceleration it wants 12.5-13.5 n it's silky smooth. At 14.5 it will buck n jerk like crazy. That's because of my cam n intake I'm sure. Back 4 plugs are always darker than the front but I did a compression test at 10,000 miles n I'm within 3% on every hole so no washdown worries. Even gets 22 mpg on the open loop tune. I like the fibreglass bolt n spacer idea though. I'm gonna give that a shot every little bit does help
I don't really care about closed loop correction on a hot rod. I just like being able to modify my fuel and spark curve with the laptop.
-- Joe
1 Post
Car: 91 Z-28
Engine: 420 sbc
That is weird because cold start and warm up driving have never been an issue. Left those tables mostly stock. Always fires within 2 seconds. Fuel heating is really the only thing I have left to figure out. It will start to buck a little n I look at the fuel pressure gauge to see the pressure drop n then the wideband confirms it
-- Joe
1 Post
Car: 91 Z-28
Engine: 420 sbc
I guess my fiberglass hood is working well for me. I've measured the blower at 125* at idle. Nothing near 250 besides the headers. That's crazy hot n definitely could be ur problem!
1 Post
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I've started driving my Trans Am again with the Minirammed 385. I run a FAST XFI fuel injection system (serial number 026) with really old firmware - and it's still currently batch fire. I'm considering buying the FAST distributor and converting it to sequential fuel injection so that I can fiddle with fuel trim on the cylinders. I've created an eight-channel EGT module, and I have eight EGT thermocouples, but no holes in my headers as-of-yet....
My problem isn't in starting, it's in the fact that when things get hot, part-throttle cruising around town, it will sometimes backfire into the manifold and snuff out the engine for a second. It seems to lean out under some conditions and cause the pop.
I haven't ever figured out a way around it. Maybe double the Accelerator enrichment curve? I just don't quite know where to go on the tune.
Oh, and... hello to all you long-term third-genners on this thread ! It's been quite a long time since I played with cars. I took almost seven years off. How did that happen?
Things like... (and these may 7730 specific, so I'm not sure what you're running)
Accelerator enrichment....
AE delta TPS vs coolant
AE delta map vs coolant
Air temp.... not sure what kind of intake ducting you're running, but if you're still running the old TPI Inv MAT Term Lookup table you're going to have problems (especially on a Miniram).
I've also had a lot of success with the AE TPS scale factor in the fuel constants table (note this is NOT the PW scale factor). THere are two requirements that read very similarly. Both are set to .125 from the factory, but I have my AE delta TPS scale f factor set at .300. It seems to make the AE delta TPS react much faster (solving my neutral throttle blip hesitation issue).
Any rate, if you're running a 7730 ECM, PM me your e-mail address... You can try my Miniram Start Bin 2.0 and see if you get better tuning results using that as a baseline.
I made an interesting discovery yesterday. I pulled the passenger side fuel rail to start drilling for the front crossover. Fortunately I started examining it more closely before I started drilling.
Started examining the interior found that it consists of two passages that run the length of the rail. An upper and a lower passage. The main fuel line coming in at the rear feeds the lower passage which the injectors draw from. At the front, the lower passage connects to the upper passage which then runs all the way back to the rear and feeds the rear crossover. I didn't pull off the driver side rail, but my suspicion is that the fuel enters the upper passage from the crossover, runs to the front where it connects to the lower passage. From there, it runs back to the rear, feeding the injectors with the excess exiting out the regulator.
So in effect, the front crossover is integral into how the fuel rails are designed, such that the fuel doesn't dead head into the front of the rails after all.
Thermally insulating the rails themselves seems to be all the optimization it needed.
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi Mike,
Can you post the washer and bolt part numbers?
I deal with hot fuel in NC. In the Summer, the temp and humidity can be quite high.
I am thinking about changing the factory (87 IROC Z) fuel hardline routing (drive shaft tunnel). My guess is the fuel system picks up lots of heat being so close to the exhaust. Especially post cat-con.
Best Regards,
Bruce
Best Regards,
Bruce
Hey Bruce, sorry.... haven't been in this Aftermarket Intake forum in a while...
I got my bolts from McMaster Carr. Few different styles to choose from...
https://www.mcmaster.com/#fiberglass...bolts/=1b1lv5r
PTFE washers are here...
https://www.mcmaster.com/#ptfe-washers/=1b1lwri
Just remember, don't torque the bolts like they're metal. I only put a few in-lb on mine. They have enough running friction with the intake threads such that they don't back out (and the reality is they're not under a lot of dynamic loading just holding down the fuel rails, and the injector O-ring seals are not related to bolt torque).
Car: 87 IROC
Engine: 420 EFI
Thanks Mike,
I am am not familiar with this type of bolt.
Are there any longer term issues when installed in aluminum or exercised over numerous temperature cycles? What about vibration based fatigue?
As long as the bolts do not break or stick in the aluminum, we should be go to go.
I am very interested in this bolt and washer setup. NC is very hot in the Summer. When E10 fuel came to the market, I started having vapor lock fueling symptoms.
Best Regards,
Bruce
Best Regards,
Bruce
Bruce,
Not that I'm aware of. Matter of fact, I just went ahead and removed each one successfully without any binding or sticking (just to test it). I now have about 8 months of operational time on them and I did drive the car quite a bit last year, so they've been excercised.
The good thing is that glass reinforced epoxy has a higher CTE than aluminum, which means when things get hot, the aluminum fuel rail expansion (in the direction axial to the bolt) won't be putting any additional load on the bolt. In fact the bolt should be relieving itself a little since it'll be expanding at a faster rate than the aluminum. So in that regard, there won't be any thermal cycle loading going on.
If you're worried about it, what you could do is put some anti-seize on the bolts and buy a bunch of extra and simply replace them once a year. On a Miniram, you could literally replace all the bolts in a couple of minutes.
Couple of other options come to mind as well....
1.) Just put the PTFE washers between the fuel-rail/manifold and under the bolt head, but use a standard steel bolt. It could be that you get 99% of the benefit by just doing this as there may not be sufficient contact between the steel bolt and the barrel of the hole to generate significant heat transfer.
2.) Drill out the holes in the fuel rail a little and put in a plastic sleeve to insulate the bolt, then use a steel bolt. Looking at the rails, my guess is there's sufficient material in there to accommodate a larger diameter through hole. McMaster has all sorts of sleeves and spacers... you'd only need a thin wall thickness to create a good insulator. Say 1/16", which means you'd only have to go 1/8" larger on the diameter. McMaster may already have something, or you could find something close and modify it.
