Repairing curb rash
Car: 92RS
Engine: 305tbi
Repairing curb rash
Well I did my search today to see if anyone knew how to fix curb rash. But I came up empty. Does anyone know how to fix curb rash? A couple of my rims are pretty bad looking and the scratched go in kinda deep. If anyone has an idea or knows, please post. Thanks.
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
You might be able to do some kind of polishing job. But pics would give us a better idea about how bad it might be.
1 Post
Car: 89 Formula Firebird
Engine: 305 - Demon 525
By the looks for it how deep are the scratchs? You can only Grind they down so far.
1 Post
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: Repairing curb rash
Sorry to jack, but how could I fix this?
Click me to see
enlarged picture.
I want to autocross my car on race rubber and was planning to use this wheel since I would be getting a deal on it? Could I just file down the outside lip so it doesn't tear into the side of a $200+ tire, or is it a lost cause?
Click me to see
enlarged picture.
Car: 87 GTA
Pics are hard to judge by, but that looks pretty deep.
Smaller scratches can be ground/polished out. Deeper ones may be a lost cause, or a professional shop can re-weld a bead to build it back up, then grind it down to where it should be.
But for strictly race wheels, I wouldn't worry about it too much. Mounting the tires won't damage them from that. Besides, score you some crosslace wheels, and shave even more pounds off the suspension.
1 Post
Car: 1987 IROC-Z
Transmission: TH350
I just want a smooth surface for the tire to mount to this way it wont hurt the tire if it would roll over the rim from the g's during autocrossing. Any idea how much it would cost at a shop? It's an aluminum wheel and I heard its a lot more expensive to work with aluminum, is this true?
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
There's a place down here in Tucson who will completely re-do a wheel. Curb rash, paint/coating, yada yada. Make them look brand new for $200 a wheel. Just getting the rash fixed would most likely be cheaper.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
It doesnt look too bad from the pic, I'd just hit it with a file and forget about it if your just using them for autocrossing, obviously not the prettiest wheel but it should work just fine.
1 Post
Car: 1987 IROC-Z
Transmission: TH350
I can't use a cross lace wheel because it is not stock on the camaro's and I would be bumped out of stock class if I used them.
On a side note... I'm now a senior member! ...not that it means anything...
Car: 87 GTA
Thats exactly what I thought. Since I'm still in high school, money is extra tight so running it with a 'chance' of ruining the tire doesn't sit well with me. I was also wondering, would filing it down on the inside edge of the lip (where the tire contacts the wheel) make more of a gap and let air out because of the bad seal?
You can do a complete Z28/GTA chassis swap, to a RS or base Firebird. Chassis-wise, it's no different.
Between V6 & V8, there is a classification difference. Here's my wife's F Stock car, that ended up in SM, because of the hood & soft compound, "slicks". We were there to have fun, not purely to win and adhere to the rules. When our classification got bumped, we didn't care/
1 Post
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
Yikes, that looks like crap! Did you let your girlfriend drive? Seriously, unless you can find a place that can build up the bead again and them machine it down(college/high school metalshop class or ?) it might be better to find another wheel...
