what to do
Old Jun 21, 2005 | 09:05 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
what to do
here is my car now i want it to look like the #2 pic how much of a drop.
Old Jun 21, 2005 | 09:06 PM
Car: 1987 iroc z
#2 im sure i cant get it that low but somewhat like it
Old Jun 21, 2005 | 09:12 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
Bag it. Only way you can slam it that low and keep it driveable. BAgs wouldnt be to bad on it either since it appears to be a drag car you'll have tons of adjustibility
Old Jun 21, 2005 | 09:23 PM
Car: 1987 iroc z
never really thought of that how much do you think the hole set up would cost
Old Jun 21, 2005 | 10:24 PM
Dark Mavis's Avatar
Car: 94 Camaro Z28
Engine: 5.7L
Axle/Gears: GU5 3.23
Your pipe clearance would be absolutely insane. Goodbye speedbumps.
Old Jun 21, 2005 | 10:30 PM
[VU]Juan's Avatar
Car: 84 TransAM
Engine: Chevy 355
Transmission: TH350
i wouldn't drop it that much even if it is a drag car... i would be affraid of clearance issues and more than anything the back tires getting cut by the back fenders when it slams down during launch... just my 2 cents..
Old Jun 21, 2005 | 10:31 PM
AT9305RS's Avatar
Car: 91 Bird
Engine: 3.1 w00t
Transmission: 7hundo
Axle/Gears: bent
http://www.ridetech.com/productinfo/coolride.asp
all the way at the bottom
Old Jun 22, 2005 | 02:26 AM
CrazyHawaiian's Avatar
Car: too many ...
You could use weight jacks and custom height springs to get that low but your exhaust setup looks like it hangs pretty low so IMO thats the factor that will hold you back from dropping it as low as you want. My Z28 sits at about the height in the pic #2 maybe 1/4 or 1/2 inch higher and it is still streetable although I do not have a low hanging exhaust. Air Ride would be the ultimate but if you cant afford it (like I couldnt) then the weight jacks are a winner. You also get to specify what spring rates you want when you order those springs. If you want more info on the weight jacks try a search I made a pretty good post in the suspension forum.
