Spoiler Delete?
Old Jun 29, 2007 | 05:28 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Spoiler Delete?
So my camaro is going to the paint shope next thursday and i've came up with my paint scheme white(blue stripes) and would like to know your opinions on a spoiler delete.
Also would like pics of cars w/o spoiler, i believe that there were some california irocs that came w/o spoilers.
Old Jun 29, 2007 | 09:16 PM
stroker_SS's Avatar
Engine: 355
Re: Spoiler Delete?
I was also wondering whats involved in putting GFX on a car that originally came without them.
Old Jun 30, 2007 | 01:29 PM
TA5point0's Avatar
Car: 89 trans am
Engine: 305 tpi
Re: Spoiler Delete?
i personally would keep the spoiler... and as far as the ground effects u just need to bolt them on.. most youd have to do is drill the holes if they arent allready on ur car
Old Jun 30, 2007 | 01:53 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Spoiler Delete?
You'll need a new front bumper cover, though, to put the front ground effects on.
The spoiler delete only looks good if the car is lowered and has gfx and has the perfect stance for it, otherwise it just looks like crap.
Old Jun 30, 2007 | 11:52 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Re: Spoiler Delete?
No spoiler delete, please. I just don't think a thirdgen looks like a thirdgen without a spoiler.
Old Jul 1, 2007 | 12:09 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Spoiler Delete?
I agree with most of the replys that the spoiler should definitely stay ON the car. gfx should bolt up with a few holes drilled in and screws.
Old Jul 1, 2007 | 01:13 AM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
Re: Spoiler Delete?
camaros look terrible w/o a spoiler. I've only seen a few 3rdgen TA's pull off no spoiler, but for the most part 3rdgens need a spoiler.
Old Jul 1, 2007 | 09:26 AM
stroker_SS's Avatar
Engine: 355
Re: Spoiler Delete?
Just today i pulled the spoiler off and i realized that it would just be missing something if I left the spoiler off. Thanks for the replies however!
Old Jul 1, 2007 | 10:04 AM
BuiltZ28's Avatar
Re: Spoiler Delete?
Putting GFX on a non equipped car involves slightly more then just a few holes with the makita.
These pieces are old and alot of times the studs are old and stripped if not broken and missing.
The side skirts require brackets to be tack welded to the car, good luck finding oem ones in good shape. If I can recall I took some 1/4" steel and bent it at a 90 or so and used that.
It was more of a headache than I had imagined, getting them to line up properly to please the eye is half the battle.
Old Jul 1, 2007 | 11:53 AM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
Re: Spoiler Delete?
heres a link i used to put my gfx on my old sport coupe. http://www.cardomain.com/ride/824993
Old Jul 3, 2007 | 12:56 AM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
Re: Spoiler Delete?
if you run big and litlle tires, you could get away without a spoiler.
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
