Intake painted black! pics!
Well I got bored and decided to take off the plenum and paint it black. I got some engine degreaser and cleaned it off with a wire brush, then washed it off and dryed it. Then I primered it with 500 degree engine primer and painted it with 500 degree gloss black engine enamel. I did the IAC housing and the coolant cavity cover. I am also going to do the runners, intake manifold and throttle body as well, but I am buying new ones so it will have to wait. I think it looks pretty good! What to you guys think?
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Intake painted black! pics!
Looks great!
I would mask off the "Tuned Port Injection" and paint it a different color. And maybe the "ribs" on the top of the intake too.
But that's just my
But that's just my
Engine: 4++,350 & 305 CIs
just run a flat file across the lettering on your t-body cover to remove the paint..
Not bad. I did the same thing as you. However, I decided to take it one step further and two a two tone black/red. I even bought a set of ball milled aluminum valve covers and did them up to match.
http://i20.photobucket.com/albums/b2...y/IMAG0070.jpg
Bro! Your car looks amazing!!!! Absolutely beautiful! That was very artistic!
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Aluminum doesn't rust, lol. But, if you sand down the letters, maybe you could clear coat it to prevent the corrosion?
Doesnt rust??? Learn somethin new everyday! K well I think I will still go with the paint for the corrosion protection then.
Hey FireDemonSiC, what kind of valve covers are those????
Aluminum on the other hand, DOES oxidize (aka rust), but because oxidized layer has molecules even with each other it does not flake off and actually forms a protective layer to the metal. That dull gray color aluminum turns to over time is the oxidation process.
The valve covers I actually picked up off Ebay:
http://cgi.ebay.com/ebaymotors/Sbc-B...Q5fAccessories
All they will require is some scuffing with 220 grit sandpaper since they are polished and will not provide a good surface for the paint to stick to.
Thanks for the compliments on the engine bay guys, but I still have much to do. It is far from perfect!
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
i would love to do that also but dont know how to get it different colors.
Car: 2011 2LT RS
That looks sharp! I did that on my 87vette a few years ago. Gloss black looks great. Be careful when putting the intake back together. It's really easy to scratch it when trying to get the torx bolts back in I would leave it black the way it is and just sand off the black on the letters for the TB plate. Don't fill in the lines of the plenum. It makes it look cheesy IMHO if its a different color. Black is perfect.
Na I think I'm going to go with silver. Especially because my paint job will practically match it. But I gotta agree with you, Black is killer!!!!
Heres a link to another thread of mine so you can see my paint scheme...
https://www.thirdgen.org/forums/body...o-i-paint.html
To do the stripes I actually used a very crude method.
I painted the piece the base black, then within 1 hour after I allowed it to dry some I found something that acted as a jig so I could cut strips of scotch tape exactly the correct width. I then placed these strips over top of the areas around the stripes I DIDN'T want red, then fixed something such as newspaper or gift wrap covering the entire rest of the piece to mask it off. After I removed the tape, I sprayed the whole thing with ceramic engine clearcoat. It really gives it a rich shine and helps the two different layers of paint to blend well.
This method is far from perfect. And when I lifted the tape there were a couple spots where it even took up a piece or two of the black which led me to spraypainting inside the can top and using a paintbrush for touchup work. Also by using this method, the ends of the strips will never be perfect. You can work with them a bit but they will have a square effect to them rather than a rounded effect. But I think it works out good enough.
In the comparison picture here the finished valve cover look s a little hazy because it hadn't gone in the oven yet. The final product can be found in this thread:
https://www.thirdgen.org/forums/tech...-covers-w.html
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Im suprised that no one has mentioned it, but you could always sand off the paint on the raised part and polish it. Just a thought.
Engine: V8 305 TPI
when you guys decide to paint intake 2 colors or something and you want a base color and the lines another color, how do you section it off?
Im going to try tape, painters or just plain scotch. Either way should work. I ordered the valve covers so they should be here around the 22nd. When they come in, I am going to paint those and then add the silver to all of them. I will throw up a thread on that as well when Im done.
1 Post
Car: 91 GTA / 68 Mustang Coupe
Engine: LB9 305 / 302
Didn't realize how good that would look it just black. I personally wouldn't color the ribs, I'd just do the TPI in another color. But hey, any way you dice it... it looks good.
Engine: V8 305 TPI
Well I decided to do the silver. I think it came out very nice! I just got some engine enamel and sprayed it into a container and then used a very narrow paintbrush. The letters were easy, but the ribs took 3 coats to come out right. Check it out!!!
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Looks really good. If I wasn't going for the original/stock look on my car, i'd do that in a second.
hey guys, glad u all like it! i totally love the look! i will be ordering the intake manifold and runners from edelbrock sometime in the near future and paint that to match as well. i did receive my valve covers and will paint those and throw up some pics whenever i get around to it. look out for that sometime in the next couple weeks. until then, enjoy!
Got the valve covers done! well almost fully done, minus the silver. heres the link...
https://www.thirdgen.org/forums/auto...ml#post4795772
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Looks Sweet!
I was farting around with my brother's 3.1 when rebuilding it. I filed the rounded ribs flat and coated it with VHT wrinkle finish.
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
old thread, but I wanted to bump it for more ideas for creative plenums, and give props to firedemon for an great job on his
Ya firedemon did a wicked job! I hate to copy but I gotta! My valve covers are already black and I just need to add the silver into the lines. I will get around to that soon....
ambainb
04-25-2016 09:21 PM
kah992
08-19-2015 02:55 PM
