HELP shifter QUESTION
Old Feb 6, 2003 | 03:54 PM
armymp1983's Avatar
hey i got a different shifter for my 1988 camaro. it is the 5 speed trans. i can't figure out how to get the old leather ball off the damn thing. how does this come off. does it screw off, pop off, or is it glued on some one help me out i am frustrated i am about to take a hammer to it!!!!!!!!!!!!!!!!!!!!
Old Feb 6, 2003 | 03:58 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Hey! The shifter **** should unscrew if you turn it in a counterclockwise direction. I know that's how it is on my '84 TA, both with the stock T-5 and shifter and with the new T-56 and Hurst Billet Plus shifter. It's probably screwed on pretty tight, but you should be able to just grab it and unscrew it! Good luck!
-Paul
Old Feb 6, 2003 | 04:00 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Yeah, you probaly need to turn harder or spray some penatrating spray lube on the bottom of it.
MustangBeater20
Oct 29, 2022 09:20 PM
BewleyBizzIROC
Feb 3, 2020 09:52 AM
NBrehm
Aug 25, 2015 11:49 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
