will this be an easy fix? pic inside
Old Feb 1, 2004 | 07:59 AM
91n99fbodies's Avatar
Car: 91z28
Engine: LB9 305TPI
the car used to belong to my ex girlfriend, she hit a wall at a car wash, tried to back up and ripped the nose off the car. the insurance company didnt want to fix it without totalling it out, so i bought it off of her for real cheap. am I gonna need a whole nose assembly or would it be easier just replacing the parts that i absolutely need? also wiill the bumper cover from a 91-92 rs work as well, since there seems to be a lot more of those around than z28's?
Old Feb 1, 2004 | 08:07 AM
AaronIROCZ's Avatar
Moderator/TGO Supporter
from the looks in the picture you will also need a headlight bar that goes across the whole front end of the car to hold the headlights. On the nose, if the tabs to where you mount the nose to the car are torn then you better start looking for a different one. Unless you can fix the broken tabs I am not sure on that. You can look from 85 to 92 camaros z28, iroc, and rs, the main part of the nose is the same just the ground effects are from 85-90 different from 90-92. Just my opinion looks like a easy fix, could be done in a day.
Old Feb 1, 2004 | 02:59 PM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
or you could sell the car to me if you don't wanna mess with it
Old Feb 1, 2004 | 05:36 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Thats an easy fix, I replaced everything doors forvard on my IROC when i nosed an elantra, so jus go to a junkyard and grab a complete nose, with the lught pannel and everything, make sure you grab all the brackets adn as much as you can, everything fender forvards you should take, just in case. If you dont kno how to line it up and put it on, take it to a shop. Should be nothing
Old Feb 2, 2004 | 01:42 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
sweet *** car man fix that up!!
Old Feb 2, 2004 | 03:28 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
nice easy fix probably a day or 2
Old Feb 2, 2004 | 03:32 PM
Red87SC's Avatar
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
is there anything wrong with that nose? im looking to buy one and was wondering if u want to sell it. if not the whole nose, how much for just the front spoiler? thanx man. whatever you do with it, it will look very nice.
Old Feb 2, 2004 | 05:19 PM
fyrechikyn's Avatar
looks like an easy fix if anything isnt broken to severely just straighten out the sheet metal and put the cover back on pics would help alot though
Old Feb 3, 2004 | 04:04 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
SHould be a easy fix. depending on if it riped or tweeked the metal bumper supports. Even then its not to much more hassle.
I see your in Ohio. drop me a e-mail If your close enough I could come help. Im in the ohio/pa area zip 44438
Old Feb 4, 2004 | 01:08 AM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
thats nothin compared to my camaro I had to fix up, I did all this work in very little time. I had it torn down and then rebuilt by myself *Cept for body shop fixin frame $450, lol* in about aday
Old Feb 11, 2004 | 01:12 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
i can't believe they'd try to total that car out! It doesn't even look like the fender was touched... at least no damage that can't be fixed without replacing it. It looks like you got some good advice so far. The nose itself still looks good for the most part. Maybe some of the studs need to be apoxyed back into the nose. It looks like you got a great deal there with the minimal work required
evan555222
Sep 20, 2016 02:51 AM
Dkelz313
Apr 7, 2016 10:38 PM
evan555222
Aug 22, 2015 07:14 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
