T-Top trim needed
Old Mar 27, 2007 | 12:53 PM
FIII's Avatar
Car: 88 Formula
T-Top trim needed
I need the trim piece that mounts to the t-top and covers the outside edge of the glass (drip edge/rail?) You can see the piece I'm talking about in the picture. Mine is falling off and just plain screwed-up. Is this still available? I borrowed the pic from 'frenchians' thread.....
Old Mar 27, 2007 | 01:02 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
Re: T-Top trim needed
i have the same problem... mine is hanging, ripped and missing a chunk. ive been looking for that piece for a while and havent come up with anything.... hopefully someone else on here can help us out
Old Mar 27, 2007 | 01:24 PM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
can this piece be removed from one t top to another? ive got the same problem but ive got a spare set of t tops i could borrow from.
Old Mar 27, 2007 | 01:49 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
We all have the same problem. What would happen if we remove it altogther?
Old Mar 27, 2007 | 01:57 PM
FIII's Avatar
Car: 88 Formula
I may take that route and remove it.....
gmpartsdirect.com shows what looks to be a replacement piece but the diagram they show is not very clear.
Old Mar 27, 2007 | 04:29 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
do you have the page address i couldnt find anything on that site... i may be the guinea pig to see if thats the part or not. i imagine that if its removed its just another place to let water in so I'd like to get a replacement.
Old Mar 28, 2007 | 09:39 AM
Car: 92 Camaro RS
Engine: 5.0L
anyone taken these off before? how hard is it to switch the strip from one top to another?
Old Mar 28, 2007 | 10:44 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I removed mine and so far no problem. I'm in So. Calif. though and there hasn't been much rain this year. There might be a little bit more wind noise but i listen to my music loud so not real sure.
Old Mar 31, 2007 | 06:16 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Not cheap, but I think this is what you seek:
T-Tops Weatherstrip
Old Mar 31, 2007 | 09:45 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
no no, already have the weatherstrip.. just need the little piece that hangs over the door.
Old Apr 1, 2007 | 05:21 PM
wildjeff's Avatar
Car: 1983 Trans Am
Engine: L69 5.0L HO
Transmission: Manual
I just bought a set from gmpartsdirect.com,
Part numbers are;
Side Rail Seal RH 10198352
Side Rail Seal LH 10198353
The original ones are a firm rubber, the new replacement ones from GM are plastic. You can take the trim off the top and replace it but it’s a pain, at least mine where.
Old Apr 1, 2007 | 05:30 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
did they come with red tape on them? the seal kit i have has 2 plastic pieces that look about that size... didnt put 1 and 1 together
Old Apr 1, 2007 | 11:50 PM
wildjeff's Avatar
Car: 1983 Trans Am
Engine: L69 5.0L HO
Yes, the red strip is on the double sided foam tape. It gets pealed off before installation so the foam strip will adhere to the T-Top and form a seal.
Old Apr 2, 2007 | 12:43 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Ahhh now i get it.. its all so clear
Old Apr 2, 2007 | 03:18 PM
FIII's Avatar
Car: 88 Formula
thanks wildjeff...........just what I was looking for......
so, how big of a pain was it to replace these pieces?
Old Apr 2, 2007 | 03:30 PM
1989GTABlown632's Avatar
Car: 1989 Pontiac Firebird Trans-Am GTA
Engine: Blown 632 CID with Nitrous
Transmission: TH400
Axle/Gears: 4:10
You can also get them from fbody motorsports I think they were 49.00 each. I orderd 2 about 6 months ago they were a rubber plastic mix to replace the orignal they seem to work better. Heres a link to Strips. GM T-top Seal Retainer Strip http://www.fbodymotorsports.com/inc/sdetail/2212 if you call them and describe that part they can do it over the phone.
Old Dec 18, 2007 | 06:17 PM
1986lt1boy's Avatar
Car: 1986 Trans AM
Engine: 396 LT1 Stroker
Axle/Gears: Ford 9 Inch w/ 3:70 Gears
Do any of you who replaced the strips have a pic of what the new replacement ones look like?
Old Dec 18, 2007 | 06:34 PM
cdoyle's Avatar
I would like to see this too, the pic of the one for sale couldn't get any smaller.
Old Dec 19, 2007 | 12:53 AM
odecca's Avatar
Car: 89 RS
Engine: 305... for now.
I replace the trim and weather stripping on an 93 I had. not too dificult as I recall. got mine from Year One. I think it was made by Soft Seal?
lee01
Apr 9, 2016 01:56 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
