Drivers side door help.
Old Jun 14, 2007 | 01:21 PM
EMc513's Avatar
My drivers side door rattles everytime I close it. The hinges are tight and seem to be adjusted right and the door lines up right or seems to be. Inspecting the door from the exterior it appears that it is not tight enough up against the glass/interior. I can actually grip the door from above with the window down and squeeze it together. This play does not exist in my passanger side door. There is definitely a noticeable gap between the window and rubber stripping attatched to the door from the exterior. Which also does not exist on my passanger side door. Anyone seen this before? I can post Pics if needed.
Thanks in advance for any help.
Old Jun 14, 2007 | 03:08 PM
BlueSmoke's Avatar
Car: 91 RS Camro Ttop
Engine: 5.0 LO3
Re: Drivers side door help.
loosen all the upper bolts then loosen (just enough to let it give) the bottom bolts and man handle it in position. I just swapped both doors on mine and the lining up process was a pain. I went for help on the second one and that's really all they are to it.
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
GVMV
Aug 16, 2015 07:08 PM
tecustomz
Aug 16, 2015 02:28 PM
timonator
Aug 11, 2015 09:56 PM
