PAINT HELP!!!!!!!!!!
Car: 92 Camaro RS
Engine: 350 :)
Transmission: 5 Speed
Axle/Gears: 3.73 posi 10 bolt
Hi guys, i got a ?
Im not that new to this site but i dont post much. i read a lots though. 16 and summer here im ready to start MY build.
CAR: 88 RS
2.8 to LS1 and T-56 8D
Now to my ?. about paint. i found this site and it seems reliable but i wonted to see if anyone has bout from them. heres a link> "http://www.paintforcars.com/kits_candyappleredmetallic.html" <
CAR: 88 RS
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: PAINT HELP!!!!!!!!!!
Never heard of this site or the brand. I use PPG brands shopline series for low cost jobs. This paint is a single stage where the clear coat and color go on as the same coat. It does have the option to add a clear coat over it. I would recomend a paint system that is a base coat/clear coat system. You will want to do your body work first. Then generally any areas that are filler only you will want to use an epoxy primer on. Areas that have bare metals will need a self etch (acid) primer. Then block sand all painted areas. After primer you will apply a sealer which will give the color coat a uniform color to be applied to. For a basecoat/clear system coat you will apply two color coats (the first coat needs to be light as well as uniform.) This will be followed by two coats of clear.
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
I'm about three hours or so away, close to Myrtle Beach. I'll be glad to help any way I can. I can send you my cell # if you want. Pics in my album of my car/work.
Unless you are going to keep the car inside, stay away from the "candy" colors. That stuff fades by the day. Base clear is best IMO. Even in shopline.
Beach bash for f-bodies is comming up soon. Hope to see you there.
Car: 92 Camaro RS
Engine: 350 :)
Thanks send me your # and i'll get up with you. What color would you go with. Me interior is red and white and kinda wont something to match or go along with it. Im thinikn black
Car: 92 Camaro RS
Engine: 350 :)
well im going to have to fix my door cuz some "idiot" hit it and left. i also have a lot of sanidng and bondo work to do around my t-tops. domeone tried to do it before i got it and lets just say....its bad.
Havent decided on paint maybe black.
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
If you are going black, there is a paint called concept black by ppg(dcc9000) . I personally use it all the time down at the shop. And I highly reccomend it. It is single stage but think of it this way its basically a clear with tint in it. I have seen vehicles painted with it years ago that still look amazing, in fact we (the shop) just did a 79 vette with it and it looks amazing. If you really want that mirror finish, lay 3 or 4 good coats then sand it down a bit with 2000 grit sandpaper (wet) then buff it out. (for buffing I recommend Pretas system http://www.prestaproducts.com/Ultra_...S-details.aspx)
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Sep 13, 2017 12:58 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
