heater box removal?!?
Car: Pontiac Grand Prix GTP
Engine: 3.8L V6 SuperCharged
I have my entire dash apart right now cause I need to replace the heat and sound installation behind it on the firewall (soaked with coolant from the old heater core). I have replaced the heater core already and know how to get into the housing (heater box?) that it sits in. But I need to take it off of the firewall! Anyone know how to do this? Thanks
John
84 Firebird with Trans am ground effects- 350 4bbl GM crate motor (LM1), T-Tops, automatic, K&N filter, 180* thermostat, ram-air hood scoop, flowmaster muffler, Accel cap & rotor, MSD Super Conductor Wires. Coming soon: new interior (grey), rear end work, subframe connectors, polyurethane bushings
John
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
like 3 screws inside behind matting, and about 4 or 5 nuts in the engine bay...
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
I feel your pain ... I believe it's time to start putting this damned interior back together.
I do have a question about the dash board. Right next to one of the vents, I have a crack. Is there a good way to repair this (hard plastic)? I was thinking of trying some kind of glue and sort of patch up the crack ....
Thanks Duffster, I removed several fasteners already hoping to get it off, but I think there are a couple more. Allan, is the crack visible when the assembly is back together? If not, you could use some JB weld. I did this for the fuse block cover because the tab with the spring broke off. it doesn't look the greatest, but you cant see it when its on the car, and that stuff is really strong. It is a dark grey color. Thanks for the picture, that is what my dash looks like, but everything else is out of my car (carpet, seats, headliner,console,etc). It is totally stripped and I just want to get it back together!! Thanks guys.
John
John
