Window question
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
Window question
I finally got around to trying to adjust the window in the replacement door, I put on my daughters 91 bird. The window wouldn't raise far enough. After several hours of messing with it. I checked the window against the original I took out of the bad door. And found that the hard stop holes were about 1/2" higher in the window, and the hard stop in the front of the window was completely different. Can anyone tell me what this window goes to?
John
John
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: Window question
'm not aware of the differences between years but their may be some with the windows and regulators. I'd change regulators, if they worked in your old door the pair of them should work in your new one.
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
