Squeaking blisters/louvers need help!
Old Jun 21, 2012 | 11:47 PM
KG427KG427's Avatar
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
So I mounted my louvers or blisters the black ones they were brand new from classic industries GM ones. And they are making a really bad squeaking noise. When I take them off and drive with just the hood no sound. So it's te blisters.
Do you use rtv or a glue ?
Old Jun 23, 2012 | 07:24 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: Squeaking blisters/louvers need help!
Use neither. You over tightened them when installing. Try to loosen the mounting hardware. Be sure to keep them tight, just not overtight.
Old Jun 23, 2012 | 10:46 AM
KG427KG427's Avatar
Car: 1991 camaro
Ok thank you. Ya I did them pretty tight I guess too tight
Old Jun 23, 2012 | 01:16 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
If that doesn't work try nylon or rubber washers...
Old Jun 23, 2012 | 07:38 PM
KG427KG427's Avatar
Car: 1991 camaro
So I loosened all the screws and my louvers are still squeaking !!!
What should i do
Old Jun 23, 2012 | 09:20 PM
FueledSoul's Avatar
Old Jun 23, 2012 | 10:13 PM
KG427KG427's Avatar
Car: 1991 camaro
K checking out napa tmrw see if they have something I can use/try
Thank you
elevario
Mar 1, 2002 12:10 PM
elevario
Aug 9, 2001 01:42 AM
crazeinc
Jul 30, 2001 11:58 PM
TomP
Jul 15, 2001 06:43 PM
zedder 1 9 9 0
May 16, 2001 07:20 AM
