camaro louvers
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Re: camaro louvers
factory?
should have mounting hardware otherwise you get to make your own.
Car: 1987 camaro sc
Engine: lg4 305
Re: camaro louvers
you have to more specific theres like dozen different louvers for these car could you upload a pic of them. do the louvers wrap the entire window or does it have the louvers in the middle and panels on the side with a couple holes in it. do they have hinges or a lock
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: camaro louvers
most louvers arent around anymore making hardware to to come by and almost impossible. do a search on all the other threads about louvers, dont say you cant find them because ive personally commented on about 3-4 of them. you may end up making your own brackets.
Re: camaro louvers
The louvers are 3 pc alumninum i have the hinges for the center piece just not sure how to attach them to the top of the car by the window hinge( possibly remove rear window hatch assy drill holes and screw down to roof of car?), any help would be good, i have been searching on line to no avail.
thanks
thanks
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: camaro louvers
!!!!DO NOT DRILL any holes!!!!!
Can you post pics of what you have-- louvers & hardware?
Maybe someone can tell you what to do.
84z96L31vortec
Aug 20, 2017 12:16 AM
