Those that have there engine out of there camaro... i have a question!
Old Mar 10, 2013 | 07:03 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Hopefully someone car help me out, if you have your engine out of your car and body panels on and don't mind shutting the hood on your selves... I would like some pictures and measurements of the max clearance between a stock hood and the top of the core support. Im looking at building a air intake to fit between a stock hood and the top of the core support kind of like the TPI cars... If anyone can do this it would be greatly appreciated!
Old Mar 10, 2013 | 07:23 PM
BOTTLEDZ28's Avatar
Transmission: A4
Re: Those that have there engine out of there camaro... i have a question!
There is only a coupe inches maybe. Most of the TPI camaros that still use the stock dual air filter setup show signs of wear on the intake ducting from the hood rubbing it. So, if you can look at one of those pieces then you will get a good idea of the space, which isnt much.
Old Mar 12, 2013 | 09:06 PM
Cars'n'Guitars's Avatar
Car: 1985 Camaro Iroc-Z
Engine: Currently Deciding
Transmission: TH350 Built
Axle/Gears: 3.73 POSI
Wish I would have seen this a couple of days ago, I just had the engine out of my car. Sorry man I can't help but good luck.
Old Mar 20, 2013 | 02:31 PM
fyrebird68's Avatar
Put a couple of giant play-dough "mountains" on the core support, put a piece of wax paper or aluminum foil on top of them. Gently close the hood. The play- dough will squish down to the clearance height. Old trick from the hi-rise manifold guys.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
