door glass filler seal or outer glass weatherstripping?
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
ok ya know the thing on the door called the "door glass filler/run channel" well the weather stripping on the inside and outside needs to b replaced
if you have the next generation parts catalog can you please tell me what part(s) i need
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
best E.T. (dont laugh) 15.997 @86.04mph
http://www.geocities.com/K_towngangsta
check ebay, 1Aauto sells them there all the time, the outer ones are called "outer window sweeps" and the inner ones may be called inner sweeps, but basicly it's the top trim piece for the door which they are attached to. The outer ones are like 56, and the inner ones are like 125, or if you dont want to drop that much coin, try a junk yard, you'd be suprised at how often you cna find those in good shape. (HINT: look for the new arrivals)
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I bought mine from 1aauto.com. A little cheaper than next gen.
miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES,it is a 9 bolt & YES they are 3.73's, not 3.70. 4.11's to follow soon )
www.koolmeister.com
miles
88 427 Camaro
www.koolmeister.com
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
1983, 84, body, camaro, camro, car, channel, door, dur, filler, fillerrun, glass, outerglass, weaterstripping, weatherstripping
