Door Differences
Old Aug 6, 2013 | 01:00 AM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Door Differences
So, I am about to go pick the doors off of a 92' Camaro. Are there any differences I should know about in comparison to the 89' Camaro? Wiring differences for the windows? Longer? Heavier? Any comments are welcome! Thanks.
Old Aug 6, 2013 | 09:51 AM
cdoyle's Avatar
Re: Door Differences
Not sure about the wiring, but physically they are exactly the same.
I just put some 92 on my 84 and they fit OK.
Old Aug 6, 2013 | 11:41 AM
Blue1990camaro's Avatar
i just put 92 doors on my 85 iroc, fit find, however the lower body line doesnt seem to line up with the body, it seems to be 1/4 lowever then the line on the bottom of the fenders and 1/4 panel, maybe its just me but idk if its suposed to be that way, the gfx cover it so it doesnt bother me
Old Aug 6, 2013 | 04:26 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
OP the wiring is hard wired to the car so you will probably be using what is on your car anyway. Not sure about the door lock actuator on the different years but it's easy to change to your original. There are differences on the way the latches bolt up but the change is around the 86 model IIRC. One has countersunk bolts where the later models do not.
Old Aug 6, 2013 | 11:57 PM
No the wiring is basically the same unless it has power mirrors and u don't, DO NOT CUT THE WIRES! Unplug everything (should be 3 plugs) and pull the wire harness back out of the door where it goes in it by the hinges. If u can I'd cut the harness off the parts car incase u break any of ur own plugs, if avoiding cutting if possible. My 91 doors went on my 85 without any mods, all I did was re use my manual mirror because the 91 had power. The door lock actuator and window motors are the same. FYI u can use a 4th gen window motor in a 3rd gen door if u want faster windows, I have 4th gen motors myself
Old Aug 7, 2013 | 12:42 AM
Annihilate's Avatar
Engine: 5.0
I have an 89' the latches should be fine right?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Apr 9, 2016 10:20 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
