RUST
Old Oct 11, 2001 | 02:32 AM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
RUST
I was just wondering if anybody has done rust repair on one of our cars. I have a rust bubble on the winshield header panel on my 86 IROC. I was considering drilling out the spot welds and replacing the entire thing, but I am concerned about structual integrity, since it is a T-Top car I just want the rust gone. Any suggestions would be greatly appreciated...
1986 IROC TPI 305
Comp Cams cam, 1.6 rockers. Ported base and plenum, Hughes 700r4, 2500 stall lockup conv. Jet Hot coated Heddman headers, random tech. Cat, Flowmaster 3in cat back, 7.75 BW rear (out of 88 GTA) 3.27 gear. Full poly bushings, Bilstien shocks struts, Kenny Brown strut tower brace, and subframe connectors.
Future upgrades 355, GMPP forged steel crank, ARP main studs, and fastners, ZZ-9 cam, Comp cams Roller lifters, rockers, and pushrods. Vigalante conv, 1LE brakes, and driveshaft.
Old Oct 11, 2001 | 05:15 PM
1982chevycamaroz28's Avatar
if ur talkin about the bar by the top of the windsheild. all u do is get a metal scraper scrape off the bubbled paint to the metal, sand it with 80 grit and go to 180 and before u put like any bondo or filler in go by sum rust stop stuff from like a automotive paint store the should carry something. then fill in the spot with bondo or a good filler, wait till it sets and hardens then sand with 80 then 180 but use 180 becuz its faster and it also smooths it at te same time and then when u get it nice and smooth with the rest of the bar primer lightly sand or use a scouring pad and then used sum laquar puddy i think and that will fill in any little things u missed and with that u have to wet sand the laquar puddy and then primer and paint but make sure everything is cleaned after u do this before u paint becuz if not it will be bad. i know this becuz i have pleanty of those spots on my car this summer and i got rid of them in that way. if ur not to sure about what i said just give a local body shop a call.
mods to car
new ignition system, edelbrock intake,600 cfm q-jet,th-350 tranny, used black interior, grant stering wheel, accel plugs and wires, hookercat back, b&m shifter, emmission delete package, computer delet package and soon ac delete and in future-- hooker sump comp headers, posi rear, drag slicks and all new rims probably weld rims, line lock, 8 point roll cage, strut tower brace, drag shocks, sfc, new edelbroc 600 carb, nitrous and a weiand supercharger or a 350 or 400 block
Old Oct 12, 2001 | 01:03 PM
Going Slow Sucks's Avatar
If the rust spot is not to bad you should get it sand blasted to get rid of all the rust.Rust paint will only cover the rust for, as long as it can.If the rust is deep you should think about a cutting the rust out.
P.S
If you can look behind the winshild moulding sometims rust can form in there too.
88 Camaro IROC-Z
350TPI
K&N filter , High flow exgaust (no cat's), automatic tran's shift kit
Old Oct 12, 2001 | 01:04 PM
P.S
88 Camaro IROC-Z
350TPI
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
