Hood Struts for fiberglass hood-Help
1 Post
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
I've had a VFN cowl hood on my car after I put a procharger in my car a couple of years ago. The struts that I had for my steel hood were too strong for my fiberglass hood. I was lucky enough to come across some old struts off a buick riviera, but those are now too weak to hold my fiberglass hood. Does anyone know or have any recommendations on what would work for my fiberglass hood?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Hood Struts for fiberglass hood-Help
Auto Zone handles the struts for Fiber Glass hoods.
1 Post
Car: 88 GTA, 74 T/A
Car: 92 RS Heritage
http://www.autozone.com/autozone/par...mString=search
1 Post
Car: 88 GTA, 74 T/A
This link shows the strut specifically for fiberglass hoods: (for 83 Camaro w/fiberglass hood) Aftermarket hoods may be a crapshoot.
Engine: 5.0 EFI
http://www.autozone.com/autozone/par..._0_3184%2C5635
This is for a fiber glass hood
Engine: 5.0 EFI
Minimum Force (lbs): 76.5
Maximum Force (lbs): 91.5
Car: 1990 camaro iroc
Engine: 350 vortec tpi
Transmission: built 700r4 3500 stall
Axle/Gears: 10 bolt 3.42 posi
I got the ones from advanced auto they work great specify 82-84 z28 with a fiberglass hood cheap too
Just installed a pair of FCS struts #84134 from Rock Auto for $6 each. Not too strong but just right on my aftermarket fiberglass hood. With the old worn struts I had to jiggle the hood to get one side to lift otherwise it felt like the fiberglass was cracking from the strain.
Car: 91 Z28
Engine: 350ci "fastburn 385"
Transmission: T56 / Quartermaster clutch
Axle/Gears: 9", 4.11, Auburn Posi
If anyone else comes across this, I used the 83 Camaro fiberglass hood struts from Rock Auto, and they ended up not being quite enough for my Hawk's pro-touring style hood. It must be a little more weight then some other fiberglass hoods. So I swapped one strut out with a standard strength one and now all is well, though I'm not totally happy with having two different ones on there. But it did solve the issue.
