3 problems
Old Oct 31, 2001 | 07:25 PM
elizabeth's Avatar
3 problems
My hood latch has started to not release the hood. I have to use a knife to slide in an pop the latch.
How can I repair this? Also what type of lubricant should I use on the door hinges?
I have been working on the fine tuning on the body. I am having trouble aligning the hood. It might have been slightly pushed back and down (1/4"). I have loosened the bolts on the hood to body and tried to move it without fixing the problem. I am stumped. Please give me easy directions I have to do all this by myself. Thanks.
Old Oct 31, 2001 | 07:40 PM
RODS92Z's Avatar
For one thing, lubricate the hood latch. I usually just use penetrating oil on the hood and door hinges about once a month. Doesnt hurt to lubricate the door and hatch latches too. And another thing is if the hood still doesnt pop then your hood alignment is causing it to not pop open.
1992 Camaro Z-28 custom 25th anniversary, 5.7 TPI auto, 2.73 posi, t-tops, arctic white with 92' medium mettalic gray stripes with black border stripe.
1967 Pontiac Catalina 2 door fastback, 400 v-8, auto, cameo white, dark red interior
1987 Olds Cutlass, 350 Rocket, auto, dark gray/light gray interior
Old Oct 31, 2001 | 10:08 PM
elizabeth's Avatar
A penetrating oil such as? Thanks for your help Elizabeth
Old Nov 1, 2001 | 08:51 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Bombardier makes a really good lubricant, if you can find it. Places around here that sell Snomobiles & such sell it. I figure in VA Snowmobiles are not a hot ticket, so try a place that sells Lawnmowers, ATV's or even boats. etc.
Its called simply Bombardier LUBE, and the can is purple on top, red in the middle & Yellow on the bottom.
Hope that helps
I bought a car that the latch did not work, The spring was all out of wack, I had to replace it. At the Junkyard for about $5.
The latch is adjustable, Up & down on the latch portion, right & left on the hood.
John
John
Old Nov 1, 2001 | 08:55 AM
89rsRod's Avatar
hey elizabeth, use some wd40 on those dore hinges, mine were squeeking like crazy so i sprayed some wd40 and it went away as far as your hood goes, um if its not laying straight you gotta play around with those 2 black ***** that lay under your hood, they control the hieght of the hood on each side so you can get it to lay straight. good luck with your 3rd gen f-body!
Old Nov 1, 2001 | 11:32 AM
elizabeth's Avatar
Thanks Guys!!!!What would I do wihout you'all???
I figured that the rubber things (bumpers) had something to do with it. I am out the door as we speak fixin my baby right up!!!!!
Elizabeth
John is that lube White?
Old Nov 4, 2001 | 05:46 AM
Archael's Avatar
you bet
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
