t-top outer rail
t-top outer rail
I was wondering if anyone knew of a place that sells the t-tops outer drip rail? not the seals, but the plastic/fiberglass trim.....i had mine "repaired" but they have since cracked shortly after. i'll post a pick later...
Axle/Gears: 10 Bolt 2.73 Open
Re: t-top outer rail
One of my tops needs this repair done. I have no idea what it will take to install that part.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Their easy enough to do,once you start taking them apart you will see.
gixxer92
05-18-2017 11:20 AM
Thirdgen89GTA
11-26-2015 11:04 PM
