How do you change a side mirror
Old Jan 7, 2002 | 01:02 PM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
Ok... here's the question...
My passenger side mirror is cracked (glass) and I want to replace it. The mirror is the power type.
I recently purchased a used (non-powered) complete passenger side mirror.
Can I remove the "non-powered" mirror and put it in the one on my car? If so ...how?
If I look in behind the non-powered mirror I see three screws that hold on the mirror. Would it be as simple as removing these screws and doing the same for my powered cracked one?
Old Jan 7, 2002 | 04:56 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
take it to just about any glasss shop and they will change it for you, cost me about $15-20 bucks last one & had done.
Old Jan 7, 2002 | 10:06 PM
Drew's Avatar
Or go to the replacement mirror glass section of any autoparts store and get a new glass for $7 and glue it down with epoxy or silicone and be done with it.
Old Jan 7, 2002 | 11:22 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Or, if for some reason you want go to the harder route... You can change out your mirror housings by taking off your interior door panel. With a combination of 1/4 extensions, you can get to the two nuts that attach the mirror to the door skin and swap out the mirrors. It will be easier to do the glass only, but if you're thinking about adding power mirrors or replacing a damaged mirror housing, this is the onlg way to go. See ya
Old Jan 8, 2002 | 09:20 AM
SgtSkip's Avatar
Pep Boys has the replacement mirror for $4.99. I just did my drivers side mirror.
Old Jan 8, 2002 | 01:57 PM
BirdonFire's Avatar
I had the same prob with both sides being cracked on my 91 Firebird. I went to Wal-Mart and bought a replacement sheet that was large enough to cover both sides. It comes in a 6"X10" sheet I believe. I just made me a template out of cardboard,placed it on top of the sheet and traced it,then I cut the shape out with a sturdy pair of scissors. It already has an adhesive backing,just peeled off the protective film,applied them to my mirror housing....Presto Chango....NEW MIRRORS!!!!!!!....total cost for the replacement sheet was about 5 bucks.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
89FormulaMan
Aug 10, 2015 10:01 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
