85 Z28 Steel Hood on a 84 Z28?
Car: 84 Z28
Engine: L69 305
Transmission: 5 spd T5
Axle/Gears: 3.73 posi
Greetings - -
I have a 1984 Z28, original steel hood has seen better days; showing some rust in the hidden cavities and beginning to creep. Been dinged a few times but nothing bad, the main issue is the rust that will eventally rot through to create holes. I have looked everywhere to no avail for a replacement aftermarket steel hood for the 84. I found fiberglass hoods but heard the fit badly and often delam. I have found the 1985 steel replacement hoods, and know there is a cosmetic difference with the scoops. I am wondering if that steel hood for the 85 would be a direct bolt-on for the 84. Is the hinge bolt pattern, latch, etc the same for these hoods? Is the cometic changes the only diff? Any advice is appreciated.
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: 85 Z28 Steel Hood on a 84 Z28?
Greetings - -
FIRECHICKEN
19
10-10-2013 01:17 PM
silverpace
Exterior Parts Wanted
09-18-2011 06:00 PM
HamSpiced
03-07-2004 07:25 PM
