Exterior door handles
Old 06-09-2019, 07:20 PM
96BlownSSragtop's Avatar
Car: 89 Formula
Engine: Nada - v4.0
Transmission: Nada - v3.0
Axle/Gears: Nada - v3.0
Since NOS GM is impossible to find without having to donate a body part, I tried the Dorman replacement. The studs are smaller than OEM and I can’t seem to find any speed nuts that will work.
Anyone found a solution or a replacement brand that actually works/comes with ALL hardware?
96BlownSSragtop is offline
Old 06-10-2019, 01:05 AM
Engine: LB9 305
Transmission: AT
Re: Exterior door handles
I was in the Auto Repair Business long enough to remember when Dorman was made in USA and top quality.
mikeceli is offline
Old 06-10-2019, 05:58 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I had the same problem. I noticed that if you find some ooooold stock they work perfect but the "new" stuff is garbage. I lucked out and found several NOS when needed.
TTOP350 is offline
Old 06-10-2019, 06:42 AM
Car: 1991 Z28
Transmission: auto
Originally Posted by 96BlownSSragtop View Post
Since NOS GM is impossible to find with having to donate a body part, I tried the Dorman replacement. The studs are smaller than OEM and I canít seem to find any speed nuts that will work.
I took my Doormat parts to my local body shop and he had some speed nuts that fit. That was the only way I was able to make them work. I will say it is ridiculous for a manufacturer to not include the proper hardware with their parts.
vinny R is online now
Old 06-10-2019, 08:56 AM
Engine: LB9 305
Transmission: AT
Absolutely right! For a couple pennies, Dorman could have made a repro handle that might work. Instead, they leave a "Surprise"! for the installer, to find after tearing down the door. Start driving around town, looking for a special nut, in an odd size.
mikeceli is offline
Old 06-10-2019, 10:33 AM
Car: 1986 Trans Am KITT
Axle/Gears: 4th Gen 3.73 Dash: 4th Gen
Like everything thirdgen related, I always check if I can upgrade to 4th Gen parts when possible. 4th gen door handles bolt right in and in my opinion look a little bit better. That's just my opinion though and they don't come in chrome. The new ones are probably made by Dorman too.
Firebat is offline
Old 06-10-2019, 04:49 PM
kentuckyKITT's Avatar
Car: 3 T-Tops
Engine: 327/305/305
Transmission: TH350/700R4/700R4
Axle/Gears: 3:42/2:73
Since NOS GM is impossible to find without having to donate a body part, I tried the Dorman replacement. The studs are smaller than OEM and I canít seem to find any speed nuts that will work.
I have a solution for you. I did this on my 82 and I just did this again a few days ago on a car I'm working on for someone else. As you know, the posts are too small. Made in China is always on top of their game. Also, go ahead and buy two sets of door handles and use the best pair. They like to put the posts too far up or too far down and they also like to have shotty paintwork on them. It's all garbage, but you can make the best of it.
On the speed nuts, place your FACTORY ones with the nut side up on hard metal/concrete surface, then take a hammer and tap them (don't pile drive them), tap them lightly until the top surface is flat and closes back up. They will then start on the posts after a few cusswords. Go ahead and run them on just a few threads, but not all of the way. Once on the door, then you start them again and take them all of the way. They will eventually screw all of the way down tight.
kentuckyKITT is offline
Old 06-12-2019, 05:35 PM
Car: 89 Formula
Engine: Nada - v4.0
Tried that but couldnít get it to work. Iíve ordered new NOS speed nuts and handles from 1AAuto so weíll how this works. If that doesnít work, Iíll find good used ones.
Old 06-12-2019, 09:37 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
No such thing as "good used ones".Theyre a junk design to start and only get worse once used.I used the method KITT mentioned and it worked quite well on new doorman pieces as well
84 1LE is offline
grassyflats
Fabrication
52
01-02-2011 06:00 PM
FueledSoul
06-16-2009 11:21 AM
1Aauto
Sponsored Vendors
04-27-2009 01:37 PM
18inchboyds
05-25-2005 12:50 PM
grafx
01-05-2002 08:58 PM
Quick Reply: Exterior door handles
Contact Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
