Driver's side window rattle/regulator loose Nut and Bolt Fix 91 TA
Old Apr 9, 2024 | 02:19 PM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
Attached is a photo I found on the internet, but it captures my problem.....
All 4 rivets pictured/circled in red are loose on my driver's door panel/window regulator
. Slight movement can actually be seen between the heads of the rivets and the door panel sheet metal when the window is raised and lowered, and the window itself will "rattle on the looseness" when it is energized up or down.
I realize that I need to drill out the rivets, ream the holes in the inner door sheet metal and perhaps the regulator round again and then use larger fasteners, but my question is do I do this one at a time with the window up, against the stops, fully down and "relaxed," or somewhere in between? Or does it make a difference?
Old Apr 10, 2024 | 08:29 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Re: Driver's side window rattle/regulator loose Nut and Bolt Fix 91 TA
One at a time & window up but a half inch from completely closed. At least that is how I would do it.
sedricklee
May 8, 2019 03:08 PM
Chuck
Aug 31, 2011 03:10 PM
87camaro kid
Oct 20, 2010 07:00 AM
quisterio
Mar 2, 2009 05:10 PM
1987camarosport
Feb 15, 2007 08:36 PM
