Best way to make needles RED
Old Feb 22, 2002 | 04:43 PM
Bill Krumel's Avatar
Hi guys I did the DIY White face gauges and they
turned out great. What is the best way to get
my needles red? I have one of those Red Tria PrismaColor
makers that I got from Ryan MacEwen and I think
it works like ****. The ink pools to much and I have
cleaned it off with rubbing alcohol and tried time
and time again and still can't get an even nice coat.
I suppose I could try painting somehow but thats not a
strength of mine. Anyhow please offer any suggestions
and the best way to get these Red.
THANKS!
Old Feb 22, 2002 | 04:45 PM
cac91's Avatar
I not sure if the needles are lighted or not, but if they are (like fiber optics), I'd recommend leaving them stock so they illuminate.
Old Feb 22, 2002 | 06:59 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
nail polish? what i was gonna try
Old Feb 22, 2002 | 07:32 PM
Z28DJP1987's Avatar
Model airplane paint and a very fine brush. I used bright red and
just painted the points of the needles (about 1/2 in) and they look good.
Old Feb 22, 2002 | 11:08 PM
Drew's Avatar
Until 1990 the camaro needles weren't lit. Assuming the needles you have are white, there are a couple of things you could try...
-get a bottle of red paint and dip the needle
-get a red paint pen (Walmart carries Testors paint pens for models)
-get a red permenant marker and hope the ink is thick enough.
I think I'd look into swapping to Firebird needles since they light up in orange. 90-92 Camaro needles also light up orange or yellow. I would tend to think most if not all GM apps probably would use needles that you could swap over, only concern would be the length of the needle itself.
Old Feb 22, 2002 | 11:23 PM
Drew thats a good idea about using Firebired or
later Camaro needles. Thing is I dunno if they
are the same lengh and wieght etc. I tried Testers
model paint with a fine brush and didn't really
like the results. So I figured i would use that marker
MacEwen pushes and I don't like that either...
Maybe if I would have thin'd the paint down it would
turn out better w/ Testors...
Does anybody know if there is as far as length etc
on the needles for firebirds and camaros that are illuminated?
thanks again!
Old Feb 22, 2002 | 11:39 PM
harvtherabbit's Avatar
id like to know also ive been goin for the blue dash lights and that makes the neadles look like there brownish green
Old Feb 23, 2002 | 01:55 AM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
If you don't like the markers, or the results painting by hand.. if your good at masking. Why not mask off all the needles and spray paint em? or use any air brush. it would be cleaner. and the paint would not be so thick.
Old Feb 23, 2002 | 01:06 PM
Anybody else have any ideas??
Who knows if Firebird needles will work on cable
driven Camaro Speedos? or of 90-92 camaro
needles will work on the 82-89 cable driven?
THANKS!
Old Feb 23, 2002 | 06:34 PM
FiReBReTHa's Avatar
no,
they are not designed to be used with light up firebird, im not sure if they will slide on but need to check.
the needle just needs to be sanded then painted for those who were curious....
jaridjohn
Jul 8, 2024 03:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
Linson
Aug 21, 2015 02:12 PM
