View Poll Results: Which one?
Raybestos (sp?)
33.33%
Performance Friction
66.67%
Voters: 12. You may not vote on this poll
Raybestos vs. Perfromance friction
Car: 1985 T/A
Engine: 355 TPI
i have an 85' TA with performance frictions all the way around and my car stops better than any thing i have driven and a lot of my friends say the same, i can stop with in 100 feet at over 120mph
Car: 1989 GTA
Axle/Gears: 9bolt 3.27s
There is no way you can stop from 120mph in less than 100ft, the 2002 ZO6 stops from 60 in OVER 100ft. Maybe I understood what you said wrong.
my vote goes toward raybestos brute stops !! extreme performance for the street , they're even a decent pad on the track !! lots of dust is the only draw back ..but.. the way I drive .. .any pad will dust alot
TVP
TVP
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
Car: 91 Z28
Transmission: 4L60
I have Performance Friction on all 4 corners and they dust like crazy. I'm looking at EBC Greenstuff brake pads or Hawk HP Plus Race brake pads from the tire rack.
yeah performance friction do create alot of dust. the pads can take alot of hard braking before they start fading. they r an improvement over stock pads but i want to give those ceramic pads a try. i hear they last a long time and the don't create alot of dust . if anyone has used or is using ceramic pads could u tell me what u think of them.
1 Post
Car: 91 RS
Engine: 350 TBI
I had some performance frictions on my last project, and they did stop well, but man did they start squealing in a hurry ...My father had the same problem on his car as well with them. When I went the the Raybestos PG Plus', they didn't stop as well, but they were extremely quiet throughout their lifetime and with very little brake dust.
One of my mechanics won't put in the Performance Frictions at his shop, because of the return rate of complaints he gets. He says,"I don't like to put on pads that have more metal in them than the rotors."
It sounds like fer a daily driver - Raybestos PG Plus. Assuming they stop good, if not excellent, they also are void of my main grievence - dust (I hate brake dust with a passion). Appearently they also do not squeal a lot (always good). Does this sounds correct?
hmm... I feel the need to revive my old post. any new thoughts? Also, do the performance friction squeal/sqeak much? Its a toss up between Raybestos Quiet Stop and PF Z-Rated....
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
My PFC pads don't squeal. But I also don't use the supplied "anti-squeal" shims. They're junk on any set of pads.
Apply a bead of CRC anti-squeal adhesive and whatever pads you go with should be pretty quiet.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
There is a guy who comes up to the local car meet every now and then who is an autohrozed Zaino dealer and also a dealer for Kevlar brake pads (made by EBC i think.) Supposedly they create almost no brake dust and stop very well. He runs them on his viper that he brings up there and he claims its about a 45 minutes drive for him and his wheels always look shiny as hell when he shows up.
theshackle
03-05-2017 06:37 PM
BOWTIROC
Aftermarket Product Review
07-12-2001 05:57 AM
