Brake upgrades and wheel fitment
#101
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Brake upgrades and wheel fitment
flynbye has some wilwoods tht fit on stock gta laces http://flynbye.com/catalog/i6.html
#102
Car: 1988 GTA
Engine: 383 Stroker L98 TPI
Transmission: 700 R4 w/ B&M Shift Kit
Axle/Gears: Stock BW LS 9 Bolt with 3.27 gears
Thanks 91CC.
So - 12" PBR's will fit on the rear behind 16" GTA crosslaced rear wheels.
And 13" C4's will fit on the front behind 16" GTA crosslaced front wheels.
I know different wheels have issues and just want to confirm since I don't want to give up my 16" GTA wheels.
Mike
Mike
#103
I stand corrected the 13's don't fit the crosslace but will fit the formula wheel I have. I guess that leaves you with the 1LE brakes or the 12" C4's up front.
#105
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Question about fitment.... how will the various brake upgrades fit with the stock spares? I was looking at LS1 rear and either LS1 or C5 fronts
#106
Anyone know for sure if the C5 front brake setup will fit under a set of factory 4th gen SS (zr1 style) wheels?
Would like to pull the trigger but don't want to spend all this $$$ and end up with brakes that don't fit under the wheels I have.
Just about read every thread that comes up when searching the terms "C5" and "Brakes" on this forum.
#107
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
I am doing the same as you.
Have a low mileage car so I believe I will opt for the 1LE
#108
Car: 87 Iroc, 73 Camaro, 98 RS
Engine: 350, 572 eventually, V6
Transmission: 700R4, T56, Auto
Axle/Gears: 3.73, TBD, Stock
Hello guys, I'm looking to see if anyone has fit C6 Z06 14" 6pos brakes underneath Devino adana DV430 18x8.5 wheels? I tend to think the diameter will be ok, it's the back spacing that I'm concerned with. Does anyone have a measurement from the face of the hub to the outside of the caliper (the part closest to the wheel)? Thanks in advance for your guys help. Oh, and this is bolting up on my 87 Iroc, or so I hope.
#109
Car: 89 Z28
Engine: 355 full roller, Brodix 10X heads
Transmission: Close ratio Muncie
Axle/Gears: 3.42/7.5
Anybody tried Bassett or Aero 15" circle track wheels with LS1 front/rear combo? Spacers aren't an issue, I have 3" ARP studs...
#112
Car: 1991 Camaro RS
Engine: L98 350 TPI
Read through this entire thread, and have searched other threads on this board. But most of them seem to refer to aftermarket reproduction wheels and not the original 4th gen 17" SS (ZR1 lookalikes). The closest answer I've found is the above quoted post.
#113
Car: 87' IROC
John
#114
Car: 1991 Camaro RS
Engine: L98 350 TPI
Thanks for clearing that up! I just alyaus heard it as the number of 15s ot 16s thst fit are so minimal that it is practically none
#116
Car: 1992 Z28 Blk on Blk
Engine: 409 c.i. Small Block
Transmission: Tremec TKO 2 5spd
Axle/Gears: 4.11
Will the LT1 rear disc setup work with 15" Weld racing prostars? (see pic) Rear tire size is 275/50/15 just as an FYI.
Looking at 12" rotor setup from Flynbye performance and just buying the hardware and brackets first then piecing my setup together as money comes in... http://www.flynbye.com/catalog/i182.html
Please let me know as I'm looking to buy soon.
** on another note what other pieces would I need to purchase? Obviously brake lines/ parking brake lines but what else...
#117
Car: 1986 Camaro
Axle/Gears: Stock
Does anyone know if any of the bear brake systems will fit on the stock five spoke aluminum rims on the IROC Z Z28 Camaros? I am pretty sure the smaller sizes will, but what about the larger sizes. Example 13" rotor for the front.
#118
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Transmission: TH-FO-HUNNIT
Does anyone know if front Weld RT-S S71 17" wheels will fit over the C5 brake conversion for our cars from BigBrakeUpgrade? I'm LS swapping my 239/244 cam'd LS into my 89 Firebird and I really need the stopping power from the C5 conversion and I'm planning on running 17"x7" Weld RT-S S71 wheels on the front and me and my friends have been wondering if this combo will work cuz I've been told not many wheels fit the C5 conversion... Thanks in advance for any answers
#119
Car: 1990 IROC-Z
Engine: 5.0 TBI
Has anyone tried upgraded brakes with American Racing AR23s, 15x8 wheel. I want to try LS1 brakes but don’t know what to measure. LT1 maybe?
#120
Car: 1991 Camaro RS
Hello,
Does the baer 12" Rear SS4 Brake System with Park Brake fits behind a 15 inch Bassett wheel?
I'm looking for steel wheel that fit this brake kit.
*BRAKE KIT 82-92 Camaro/Firebird Brake Kit, BAER Rear SS4 Brake System w/ 12" Rotors, (For Stock 10 Bolt With Disc)
https://baer.com/12-Rear-SS4-Brake-S...e-4302388.html
*Bassett racing DOT STREET LEGAL WHEELS 15 x 7 D-Hole Back Spacing 3" Bolt Patterns 5-on-4.75"
http://www.bassettwheel.com/dot.html
I am having a hard time fighting Japanese law.
Thanks in advance for any answers.
#121
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
#122
what parts other than LS1 Calipers, rotors from 98 SS Camaro do I need to swap disc brakes in my 86 IROCZ
#123
1 Post
Car: 91 Camaro RS
Engine: LSX 5.3 226/228 596/598 113
Axle/Gears: 3.42 Posi
I will start off by saying the 6th Gen Camaro SS front brakes with the 13.6 inch rotors will fit inside the 17 inch CTW wheels. There is about a half an inch of caliper to barrel and spoke clearance using the BIGBRAKEUPGRADE kit from Scott. This is also using pads that do not have the counter weights that protrude past the caliper. They may fit with the counter weights but it would likely be close and I would recommend just going with the pads without the counterweights.
This kit generally recommends an 18 inch rim and while doing my research I could not find anyone that had done this setup with a CTW wheel so Scott was very helpful in providing the dimensions for the 5th Gen and 6th Gen brakes to determine that on paper they would fit and once I put them on I was able to determine that there is a minimum of a half in of clearance on barrel and spoke clearance.
I have pictures as well to show the clearance.
thedevilinside (12-30-2021)
#124
#125
Car: 1992 Camaro CMC NASA
Engine: 5.3L LS
Axle/Gears: 10 in 3:42
thedevilinside (03-27-2022)
#126
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
Wheels: OE Wheels replica C7 Z06 17x9.5
Brakes: C6 Z51
Using 2” spacers with BBU brackets there’s about 1/4” gap between the wheel and the top of the caliper. Just enough clearance to accommodate balance weights as needed.
Brakes: C6 Z51
#127
Car: 89' Firebird
Engine: 3.4L V-6
Transmission: 700-R4
Axle/Gears: Whatever came stock!
Does anyone know if the 1987 16 inch Formula wheels will fit LS1 brakes?
When people refer to Formula rims,. i think they refer to the newer 88 plus concave ones with the big center caps, but im wondering about these older wheels
