LS1 front brake swap... what brake lines?
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I’m currently putting my frontend back together with all new stuff and doing my LS1 front brake swap at the same time. One problem though…. I’m using the braided stainless “Russell” brake lines and if I use the stock bracket on the strut that holds the brake line, it won’t reach the caliper. I was going to just make a custom bracket to hold the line lower and give me more slack. Any other ideas? What is everyone doing? What brake lines is everyone using? Please shed some light on this.
Thanks!
-Jeremy
Thanks!
-Jeremy
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I usually use 1LE lines from Earl's, they are about 22" in length overall.
Ed
Ed
Earl's won't sell just the front lines. You'll have to find them elsewhere.
Ed
Ed
Car: '91 GTA
Engine: 402ci LS2
Ed
Ed
Thanks!!
Car: '91 GTA
Engine: 402ci LS2
Anyone?? I'm trying to find the part number for the Earl ones. Jeg's doesn't list them and Summit only shows a set for drum cars and disc cars... nothing about 1LE or performance brake option.
Car: '91 GTA
Engine: 402ci LS2
Nevermind, just found it on Holley's website.... here you go guys!
PONTIAC MODEL YEAR APPLICATION P/N
Firebird 1989-92 w/ 4 - wh. Discs: 28A300ERL
Firebird 1985-92 Performance Package w/ 4-wh.Discs: 28A190ERL
Firebird 1984-92 Front Discs: 28A180ERL
Firebird 1982-83 Front Discs: 28A090ERL
Car: 1989 Camaro convertible
I just used the stock 1LE brake lines. I bought them at my local dealer for I think$13 a piece. I had to find the banjo bolts, cause they didn't come with my calipers. I found the right thread pitch on the rear disc brakes from a 1999 s10 blazer.
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
I bought a set of earls braided lines, just stock length. Then I moved where they mount to the strut, to the other side and flipped it upside down. Had to do a little grinding, but it worked perfectly. I could get some pictures if ya like...........
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I used stock-length Earl's brake lines and just did away with the mounts that bolt to the strut. Though I probably could have kept them actually the more I look at things.
Eric-86sc
04-03-2016 03:52 PM
