rear axle brake lines
Car: 1998 grand cherokee, 1988 iroc z
Engine: 350 tpi
Axle/Gears: ???
I was replacing the rear calipers in my '85 Z28. the brake line was frozen into the caliper so I could not get it off the caliper. in the process of trying to get it off it broke.
My question is that are there a rubber axle line available, or do need to try to find a metal lines? I'm going to do them both.
I was on classic industries and they do not have 1985 w/ disk brakes listed. will other brake lines work?
Re: rear axle brake lines
You could use either, but if you use a rubber line you just have to attach it at more points then the hard steel line. But you will most likely have to get a rubber line made special for what you are doing. Have you tried measuring the length of the line and getting a steel line from your local auto parts store?
http://www.finelinesinc.com/
http://www.inlinetube.com/
http://www.classictube.com/
I'd purchased a set since the car is 20+ years old.
JamesC
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Go with Fine Lines, time is money and they will bolt right in, no issue messing with the old lines.
Ed
Ed
