Wilwood brakes for 1992 camaro?
1 Post
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
Anyone have Wilwood front brakes for a 1992 z28 or know where I can get this setup? I already have the rear wilwood rear brakes and want to match with wilwood front setup.
I called wilwood and they said they do not make a kit for our cars except the dynalite kit with the 10.75" rotor. My rear rotors are 12.19 or 12.75" which would make it look retarded and probably wont work right if I went with smaller front rotors.
Someone please help me out here, I would be greatly appreciated. I am looking for atleast 12" rotors and I see there are kits with 14" rotors.. I plan to run 18" wheels so fitment shouldn't be a problem.
1 Post
Car: 1992 z28
Re: Wilwood brakes for 1992 camaro?
Would I be able to use wilwood calipers? Is there a kit I can look at? I want to have the same look because the rear kit has black wilwood rotors so I would like to be able to use those. ANy suggestion for that?
thanks
thanks
Car: 87' IROC
Yup the Wilwoods will be awesome. Much better than one of the GM factory swaps. Ed Miller offers these. Here is the link:
http://www.flynbye.com/catalog/i18.html
I'll receive mine in a few weeks. Will let you know how they are.
1 Post
Car: 1992 z28
Cool thanks, I actually just found these last night too
1 Post
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
I have had the 12.19 dynalite kit on my car for over a year... no problems
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
I didn't like the heavy black rotors
Switched to two piece curved vane: mock-up pic
Car: 87' IROC
How do you like your pedal feel?
More or less effort than stock?
More or less pedal travel than stock?
Street?
Auto-x?
Track days?
Road Racing?
Drag?
How much do you care about weight?
How much do you care about component life?
How much do you care about ease of pad changes?
How pretty do they have to be?
Which calipers are on the rear?
Part number for rear kit?
John
92camaroJoe
08-13-2015 06:07 AM
