LS BRAKES 84 Z28
Car: 84 Z28 camaro
Engine: 383 stroker
Transmission: turbo 350
LS BRAKES 84 Z28
I have a 84 z28 with drums. I want to do the disk rear brake conversion. I have a entire rearend out of a 99 camaro v6. I have taken the brake lines along with the calipers & the brackets that hold them. Is there anything else off the rear that i need & is the ebrake necessary? I know i need backing plates, trying to get them from ed. Any help appreciated!
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: LS BRAKES 84 Z28
I took all the e-brake stuff from the donor car, including the handle. The tunnel bracket was the tough part to remove, but I got it out. After grinding off the front cable mount on my car, I was able to bolt in (with the intention of welding) the LS1 bracket and use all the LS1 cables. The e-brake works great, BTW.
Car: 84 Z28 camaro
Engine: 383 stroker
Are the backing plates all i need to make the swap & will it be ok by them coming off a v6?
I bought my rotors, backing plates, cables and rear brackets on e-Bay. Had some braided lines fabricated locally and took the rest of what I needed from a junkyard 4th gen
My swap thread on Cascade Crew
http://cascadecrew.org/phpBB2/viewto...light=ls1+rear
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
