NEED HELP!! LS1 front swap
Old Apr 9, 2011 | 11:49 AM
norco250's Avatar
Car: 87 Iroc-z
Engine: 315 (modded 305)
Transmission: 700R4 with B&M shift kit
Axle/Gears: 10 bolt w/ 3.42's
I have almost got my from LS1 swap done, and while trying to put the caliper and caliper carrier on over the rotor, there is a huge gap between spindle and the carrier bolt holes. I have the complete setup that came off the LS1 car, but why is there such a big gap? how do I fix this? or are there 2 different types of rotors?
Brent
Old Apr 9, 2011 | 11:59 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: NEED HELP!! LS1 front swap
do you have the appropriate adapter brackets that allow you to bolt the ls1 calipers and abutments to the stock spindle? because they dont just bolt together you know.
the ls1 bracket adapter is 3/8" thick, is that the space you have?
Old Apr 9, 2011 | 03:05 PM
norco250's Avatar
Car: 87 Iroc-z
yes I have everything i needed for the swap. i modified a stock set of spindles and i have put on the adapter bracket. to me it looks like i have the wrong rotors because the offset doesn look big enough on them. does anyone have the proper part number for the correct rotors?
Old Apr 9, 2011 | 08:06 PM
norco250's Avatar
Car: 87 Iroc-z
I discovered that the problem is the hubs i bought arent machined down far enough. so the rotor doesn go all the way on.
Old Apr 11, 2011 | 09:42 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
try taking them to a place that cuts/resurfaces rotors - you may be able to get them to bevel just a little bit off the top edge (unless they are way too big), may save you some time and money over taking them to a machine shop
Old Apr 13, 2011 | 06:48 AM
norco250's Avatar
Car: 87 Iroc-z
Thanks for the tip. I was able to bring them back to the guy I bought them off of as he has a machine shop and he re-did them for me no problem. It turns out he machined the hubs to C5 rotor specs. LS1 and C5 rotors are slightly different internal diameter.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
NBrehm
Aug 25, 2015 11:49 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
