1991 Camaro RS Brake Problems
Car: 1991 Camaro RS
I have a 1991 Camaro RS that was a V6. I just put in a 305 and I ran a line first from the intake manifold to the new check valve I installed on the Brake booster. When I started the car the brake pedal went straight to the floor and fully applied the brakes. I then tried running the line off the back of the carb and the same thing happened. I wasnt sure if I needed a check valve in between the check valve on the booster and the vacuum supply as in the intake manifold or carb. My buddy has a 77 elky with a valve between his check valve at the booster and his carb, so I tried that piece off his elky on my 91 and the brake pedal still goes straight to the floor when I start the car. I'm lost, dont know if I need a new booster or what.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: 1991 Camaro RS Brake Problems
The only needed check valve is th e one on the boster itself. If the pedal foes right to the floor the booster is trashed
sailtexas186548
Exterior Parts for Sale
02-29-2016 08:40 AM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
