wilwood single piston caliper vs the dual piston - Third Generation F-Body Message Boards
Go Back  Third Generation F-Body Message Boards > Tech Boards > Brakes
Reload this Page >
Old 11-26-2018, 11:24 PM
I just bought a brand new set of wilwood 140-12097 calipers, for my 88 iroc, for $288.00, the dual piston would have been less than a $100.00 more. I spoke to a tech at wilwood who said for an occasional use street car, the single was the best choice. Has anyone out there used either set, and do you have any opinion on either? Also can anyone see an advantage to the dual when using the same size rotor and pad? Thanks
odin65 is offline
Old 11-29-2018, 07:18 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: wilwood single piston caliper vs the dual piston
I have the big single piston with drilled and slotted rotors, stop way better over stock
84 z28 is offline
Old 11-30-2018, 10:24 AM
How did you like the pads that came with them? Thanks
odin65 is offline
Old 11-30-2018, 06:49 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Pads are a BP-10 high friction pad and work great, also this is the one reason I went with the big single
The front calipers with 2.50 piston provide 4.90 square inches of piston area per caliper, in order to maintain the original front to rear brake bias and use of the OE master cylinder. The D154 is also available in a two piston version with 1.62 pistons, offering 4.12 square inches of area
https://www.wilwood.com/BrakeKits/Br...o=140-12097-BK
84 z28 is offline
Old 03-03-2019, 08:52 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
I have the dual piston one and it was a good upgrade. I think the car feels and stops so much better.
formula forever is offline
ted gerlach
33
05-15-2014 04:35 AM
Scootermunch
Brakes
02-26-2013 06:59 PM
luvofjah
Brakes
06-01-2010 10:57 AM
Quick Reply: wilwood single piston caliper vs the dual piston
Advertising
Featured Sponsors
Vendor Directory
Contact Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
