Go Back  Third Generation F-Body Message Boards > Tech Boards > Brakes
Reload this Page >
1LE Brakes and Master Cylinder Size. Dual bore (1.25" & 0.945") MC ?
Old 01-16-2019, 08:17 AM
The 1LE Calipers on Thirdgen used same piston size as the C4 Calipers which are twin 1.5 with 12 rotors. In order to keep my 15 wheels, I want to use the C4 brakes on an S10 which has a Master Cylinder of 1. My S10 rotors are only 10.5". From everything I read here, the Thirdgen with 1LE brakes used master cylinder with dual bore design (1.25" & 0.945"). However, the C4 Corvette used Master Cylinder of 15/16" bore (0.937"). Typically, the caliper piston area, master cylinder are and the brake pedal ratio are matched to provide optimum clamping power.
If I am not mistaken, the 1.25 bore on Thirdgen Master Cylinder is for the front brakes. If so then I would not have any problems using C4 calipers on my S10 if the brake pedal ratio are similar ratio. C4 may have used a smaller brake pedal which is why it may have used a Master Cylinder of 15/16" bore (0.937").
Is the 1.25 bore on Thirdgen Master Cylinder for the front brakes?
Anyone know the brake pedal ratio on the Thirdgen ?
Waid
waid786 is offline
Old 01-16-2019, 09:38 AM
Car: check
Engine: check
Transmission: check
Re: 1LE Brakes and Master Cylinder Size. Dual bore (1.25" & 0.945") MC ?
Waid
No, it is the quick-take-up section of the MC. The stock calipers are a low drag design that retracts the pads further. The 1.25" MC bore section provides a lot of fluid early on to get the pads back up against the rotor. Then the smaller main bore takes over.
RBob.
RBob is offline
Old 01-16-2019, 09:43 AM
RBob.
So I should be able to bolt on the Thirdgen M/C in the S10. Correct?
The S10 uses integrated proportioning valve that is bolted to the ABS module. Would I need to switch the the proportioning valve?
I have 8.5 rear end with disk brakes with 11.6" rotor and 1.9" caliper piston size.
Waid
waid786 is offline
Old 01-16-2019, 01:57 PM
Car: check
Engine: check
Transmission: check
Recall that the 3rd gen MC has the lines exiting toward the engine. So need to be sure that there is enough room. Another item is that the 3rd gen master may not fit into the S10 vacuum booster.
Going with a C4 MC may be a better idea.
I don't know.
Waid
BobR.
RBob is offline
.I.love.305.
10-01-2010 02:28 PM
det313
05-27-2009 05:51 PM
427camaro
Carburetors
02-27-2003 01:56 AM
CamaroX84
02-28-2002 12:29 PM
Quick Reply: 1LE Brakes and Master Cylinder Size. Dual bore (1.25" & 0.945") MC ?
Advertising
Featured Sponsors
Vendor Directory
Contact Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
