1LE rear caliper rebuild kits
Old 02-02-2019, 01:57 PM
Car: 85 Berlinetta
Axle/Gears: 10 bolt 3.42 with Torsen posi
Does Anyone have part numbers for the seal kits and pistons for 91 1LE rear PBR calipers? I have searched till my head hurt. Starting my rear rebuild and want to rebuild the calipers while Im at it.
Fullmonte77 is offline
Old 02-02-2019, 02:24 PM
Drew's Avatar
Re: 1LE rear caliper rebuild kits
NLA. Obsolete. Discontinued.
Drew is offline
Old 02-02-2019, 02:37 PM
Car: 85 Berlinetta
Well crap. Guess I will just have to clean them up good and hope for the best. They are still working fine just figured while I was at it Id replace the seals.
Old 02-02-2019, 02:57 PM
Car: 85 Berlinetta
Wouldnt the kits listed for HD rear disc be the ones I need?
Old 02-02-2019, 03:47 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Only 1 rear disc option for 89-97 and they are pretty much the same caliper.
TTOP350 is offline
Old 02-02-2019, 04:24 PM
Car: 85 Berlinetta
That makes sense. From what I have been reading the 1LE had the same caliper but had the bigger 11.6 rotor. Just so much conflicting info out there it makes your head spin.
Old 02-02-2019, 04:35 PM
TTOP350's Avatar
Same diameter rotor from 89-97. Some where in there they went with a odd offset and cast iron bracket
TTOP350 is offline
Old 02-02-2019, 08:52 PM
Drew's Avatar
Just pull up the rear discs for 89-92 on Rock Auto, and that's whats available. The cheap overhaul kits from Autozone that used to be popular, are long gone. Last I looked the individual parts are somewhat available. Don't worry about 1LE. 1LE rear discs are exactly the same as any other 89-92 rear disc. Focus on 89-92, ignore HD, ignore 1LE, because none of those buzzwords have any relevance.
Drew is offline
Old 02-02-2019, 09:14 PM
Car: 85 Berlinetta
Just pull up the rear discs for 89-92 on Rock Auto, and that's whats available. The cheap overhaul kits from Autozone that used to be d popular, are long gone. Last I looked the individual parts are somewhat available. Don't worry about 1LE. 1LE rear discs are exactly the same as any other 89-92 rear disc. Focus on 89-92, ignore HD, ignore 1LE, because none of those buzzwords have any relevance.
Yeah the more research I did the more I found that out. I just ordered rotors and caliper seal kits from Rockauto. Been reading articles all day.
Old 02-02-2019, 09:31 PM
Drew's Avatar
I gave rebuild options consideration, eventually decided my donor calipers weren't worth messing with. Picked up "rebuilt" calipers from Advance Auto, with a hefty discount code from Retailmenot.com, and some reward points. The rebuilt calipers appeared to be completely new parts. Turned out to be the best option in my case.
Drew is offline
Old 02-02-2019, 09:39 PM
Car: 85 Berlinetta
Mine are still in good shape just want to reseal them while Im redoing the rear. My car is an 85 but I got a rear from a 91 1LE car for free. Came with everything including brake cables. Im also upgrading to a zexel torsen posi. Its nice when you have friends who will help you out.
Old 02-03-2019, 10:29 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Damn Drew, those are nice!
PurelyPMD is offline
Old 02-03-2019, 07:13 PM
Abubaca's Avatar
Car: 1989 Iroc
Engine: 383 TPI
Transmission: TKO600
I purchased some reman calipers from advance just this AM. ...I pick 'em up Wednesday. I've been a little skeptical as to what I'm gonna get when I open the box. Drew's pics make me feel a little better. I'll post up pics. After core refund it'll only end up being about $60 per caliper.
Abubaca is offline
Old 02-05-2019, 08:45 AM
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: 9 bolt 3.27
Those calipers look sweet. I hope I don't need rebuild kits for mine rear PBR. If I may ask can one of you guys measure the length of the bolts that go from the abutment brackets to the backing plates? I lost mine but had extra bolts from the LS1 front brake swap that are the right thread. They look a little long tho.
Thanks in advance.
TORN is offline
Old 02-05-2019, 12:42 PM
skinny z's Avatar
Car: 86 Sport Coupe
A question and not meant to be taunting but why bother with rebuilding when a complete caliper (like Drew's or my own for that matter) are available over the counter?
skinny z is offline
Old 02-05-2019, 12:53 PM
Car: 85 Berlinetta
Mine are in very good condition. I'm rebuilding the complete rear and figured I would just replace the seals while I was at it. I would rather pay $8 each for seal kits than $60 each for new calipers.I found the rebuild kits on Rockauto. That's $100 I can put to use somewhere else on the car. If money was no object of course I would just buy reman ones. Money is getting tight at this point in time.
Old 02-05-2019, 12:55 PM
skinny z's Avatar
Car: 86 Sport Coupe
Understood. And as good an answer as any. I can relate too.
skinny z is offline
Old 02-05-2019, 01:20 PM
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I would expand on this that some "reman" parts may not be very good quality. If you buy a replacement rear caliper, it may be made in some other country and questionable quality. If I have genuine PBR calipers, they were probably made in Australia and you may not worry about them turning to junk in 100 miles, like some other parts I have purchased.
You may not even be getting the correct part, just start looking for the 12.7:1 steering boxes with the proper stops for the third gen. There is an entire thread going over that issue.
scooter is offline
Old 02-05-2019, 05:22 PM
Drew's Avatar
Truth. I mostly trust the brake caliper builders, mostly.
The Advance Auto calipers kind of surprised me. I was expecting rebuilt calipers, but what came out of the box looked like new to my eyes. Note that the caliper castings aren't exactly like the originals. They don't have all the markings like the originals, and some of the fins are a touch more squared, no PBR logos. So the question of origin is a fair one. I don't know if they're aftermarket, cast in the US, or an off-shore casting, or if PBR revised the casting. I can't really see the reman industry setting up molds and creating new calipers, but you'd think PBR would put their logo on there. Either way, it doesn't really matter to me on this particular project. If they were going on my Formula, yeah, I'd probably want a nice set of originals. For my Green Firebird, they're perfect.
Like I said, the price was pretty good too. $41/caliper after cores and discounts.
Bit hard to follow, but I got $57 worth of discounts and cashed in reward points. Then I turned in the nasty old calipers for the $80 core charge. Free shipping. Worked out to about $34 per caliper plus tax. Advance Auto is a total rip-off at full price, but after using a retailmenot.com discount code, they usually come close to Rock Auto prices. I've had employees growl at me because they say I'm getting parts for less than the employee discounts. It's kinda like Harbor Freight.
Drew is offline
Old 02-05-2019, 06:59 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Can you by chance post a link to these I've tried searching the part number on their sight, but it doesn't come up with any results. Ive tried multiple different years 89-92 and it still doesn't bring these up either.
92RS(real slow) is offline
Old 02-05-2019, 09:04 PM
skinny z's Avatar
Car: 86 Sport Coupe
If, as posted, the 4th gen PBR rear calipers are shared with the 3rd gen same, what about these?
https://www.hawksmotorsports.com/98-...r-rebuild-kit/
skinny z is offline
Old 02-06-2019, 12:53 PM
Car: 92 Firebird
Engine: 4.8 LR4
That's not all the parts that were in the original kits, but that will get you what you need done, the square O ring and the dust boot. You just have to be careful about bending the tabs on the stainless parts to change the boot out. I have the better kits, and I didn't bother with the new stainless parts, it was easy enough to just reuse what I had
scooter is offline
Old 02-06-2019, 09:20 PM
Abubaca's Avatar
Car: 1989 Iroc
Engine: 383 TPI
So slightly off topic, but since we're discussing the calipers in general, I'll point out that I did pick mine up today. Same PN# as Drew mentioned. Both calipers seem to be very well put together. ONE caliper IS in fact a PBR caliper. I opened THAT box first and was initially very happy about it. When I opened the second box, I realized this one wasn't authentic PBR, but WOW....much cleaner casting and machining. Anyhow....quick pic.
Abubaca is offline
Old 02-06-2019, 09:37 PM
Drew's Avatar
89-97 mostly the same. 98-up are completely different. 93-97 have the fins over the top of the caliper shaved down.
Using the link from my order history page, I get a 404 page. Best guess the changed the part number, or stopped selling them. Was Sept 2017 when I put in my order. The calipers they show in pics now aren't even close. But then Advance Auto has gone to **** a few times over the last few decades in their race to the bottom of the barrel.
Drew is offline
Old 02-06-2019, 09:43 PM
Drew's Avatar
Order a couple more sets until you get a matching pair, then return the odd *****. What with their absorption with CarQuest, they reboxed and rebranded a bunch of stuff. I've gotten obviously mismatched left/right rotors, calipers, wheel seals, etc. The most annoying was the front calipers, some of them are Mr T's dream in bling bling bright gold, and other's are stock looking dark gray cast iron. I've had to have them pull another pair off the shelf and open the boxes so I could make a matching pair. I'd almost expect it at this point.
Drew is offline
Old 02-06-2019, 10:13 PM
Thats what I was thinking thank you for checking. Maybe I'll just bite the bullet and order one and see what it looks like. I have a crappy set of cores I would like to swap out for some nicer ones instead of wasting the time to rebuild them
Old 02-06-2019, 10:26 PM
Drew's Avatar
No problem.
Don't forget to save your original bleeders. The correct bleeder screws aren't available anymore, and the ones that are available are too long and don't fit the original dust covers.
Drew is offline
Old 02-08-2019, 07:53 AM
No problem.
Well it's a good thing I'm pretty much a hoarder I would have saved them anyways 😅 good to know I wonder why they changed the design
Old 02-08-2019, 05:40 PM
Drew's Avatar
Best guess is the bleeders that are currently available, will thread into a wider variety of calipers. One part (sorta) fits all vs having 6 different parts for 6 different applications. The longer bleeders work, they just aren't designed to work with the captured dust covers that came on PBRs originally. Also since they have a different barbed nipple on the end, you have to have a different hose when you're bleeding all four corners, and the bleeder can get really close to the rear end and suspension.
Makes me wish I'd stocked up on the correct bleeders 10 years ago when they could still be had.
Drew is offline
Old 02-08-2019, 05:54 PM
TTOP350's Avatar
Influx of China parts and suppliers undercutting price and quality.
TTOP350 is offline
Old 02-11-2019, 10:39 AM
Car: 1985 Firebird
Transmission: TH350
No problem.
AND, I suspect, they won't allow the clearance for the left-side caliper. I'm currently diving into replacing the brake MC on our '92, and while checking the bleeder screws on the car I noticed that the left side bleeder screw was VERY close to the spring perch/panhard mount bracket on the differential:
I was going to post a query about this, but found this thread, which seemed close. How does one bleed this caliper on the car? Thanks!
gbeaird is offline
Old 02-11-2019, 10:44 AM
Car: 92 Firebird
Engine: 4.8 LR4
You can let the fluid just spray on the bracket, use a 90* piece of rubber boot to get it to shoot down, or you can unbolt the caliper. If you want to unbolt, you just rotate it down slightly, while keeping it on the rotor, After you're done, you just rotate it back and bolt it up
scooter is offline
Old 02-11-2019, 01:01 PM
Car: 1985 Firebird
Transmission: TH350
Yeah, I didn't know if there was a standard procedure everyone used. I'd thought about drilling a hole in the bracket, and others had mentioned to cut a piece of wood the thickness of the rotor and roll the caliper out to access the screw, and place the wood between the pads.
gbeaird is offline
Old 02-11-2019, 01:04 PM
Car: 92 Firebird
Engine: 4.8 LR4
Drilling a hole there isn't a bad idea either, I thought about that, but I thought you may object. Un-bolting and rotating the caliper is easier, since it's already the correct thickness
scooter is offline
Old 02-11-2019, 01:28 PM
Car: 1985 Firebird
Transmission: TH350
Yeah, not fond of drilling. I hadn't noticed the issue before, and we've owned this car for a long time. I've just never had any brake troubles. With it's history, I'm surprised how untouched the brake parts seem. It is a retired TxDPS car, and spent some time road racing before getting into the hands of autocrossers. When we got it, it was my DD for a few years, but until we bought the Firebird, it was also our autocross car, and was lent to friends to autocross when we got the Firebird.
I'll try the 'roll it out a bit' method and see how that works. I'll have to do that anyway to try my new vacuum bleeder.
Now to search for brake hoses, since some of the ones on the car look like they're weeping some.
gbeaird is offline
Dmity Kiev
Brakes
08-29-2009 02:00 PM
BigWhiteGTP
Brakes
12-06-2005 12:01 AM
norcalz28
06-04-2004 06:32 PM
Quick Reply: 1LE rear caliper rebuild kits
Advertising
Featured Sponsors
Vendor Directory
Contact Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
