1989 Rear Brakes - 1LE vs NON 1LE
Old 02-02-2019, 03:10 PM
Abubaca's Avatar
Car: 1989 Iroc
Engine: 383 TPI
Transmission: TKO600
I was under the impression that in 89, ALL cars with rear discs were the PBR caliper cars, 1LE and other. ....many places list a 1LE part and a non 1LE part. I was just curious.
Abubaca is offline
Old 02-02-2019, 03:39 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 1989 Rear Brakes - 1LE vs NON 1LE
89 and up are the same pbr setup. Well, 89 is on the 9bolt and the 90-92 is on the 10 bolt
TTOP350 is offline
Old 02-03-2019, 09:19 PM
JamesC's Avatar
Car: Met. Silver 85 IROC
Transmission: T-5 (Non-WC)
Yep. 89-92 cars are equipped with alum, single-piston PBR calipers and 11.6" rotors (the so-called 1LE or performance package; however, all rear disc brake cars, 89-92, have them). All four-wheel disc cars, regardless of year, are RPO J65.
JamesC is offline
Old 02-03-2019, 11:10 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Wonder if this has something to do with the 9-bolt that year. 89 was the only year for some brake parts because the PBR on a 9-bolt was a 1-year thing in 89 only. ( I don't know what brake parts your looking at )
I doubt all 89 1LE cars were equipped with 9-bolts ??
John in RI is offline
Old 02-03-2019, 11:24 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
They were.
chazman is offline
Old 02-03-2019, 11:49 PM
John in RI's Avatar
Then a 89 10 bolt PBR wouldn't be "1LE" ?? Right ??
Old 02-03-2019, 11:52 PM
chazman's Avatar
Axle/Gears: BW 3.45
I've never seen an '89 10 bolt with PBRs, they were all 9 bolts. '90-'92 they were 10 bolts.
chazman is offline
Old 02-04-2019, 01:55 AM
John in RI's Avatar
I find it hard to believe that not a single TBI car in 89 had rear disk brakes,... or that the all to common 89 TPI IROC/TAs with auto/2.73 rear - or T5 with 3.08 - all had drum brakes ?? The 10 bolt Auburn with disc wasn't offered at all in 89 ??
Guess I learned sumthin' new today !
Old 02-04-2019, 09:59 AM
Abubaca's Avatar
Car: 1989 Iroc
Engine: 383 TPI
I was under the impression all 89's had the 9 bolt. -but I'm not expert.
Abubaca is offline
Old 02-04-2019, 11:06 AM
chazman's Avatar
Axle/Gears: BW 3.45
In '89, all L98s and G92s got the 9 bolt. All others the 10 bolt. Also, by '89, most performance pieces were either bundled or required to be bundled together. So 4 wheel discs could only be had on a 5.7 or any G92 which required a 9 bolt.
chazman is offline
Old 02-04-2019, 11:28 AM
Abubaca's Avatar
Car: 1989 Iroc
Engine: 383 TPI
See, ya learn something new everyday.
Abubaca is offline
iroc stangs
Brakes
03-30-2019 09:15 AM
crazyjoe
02-28-2003 01:37 PM
JMatlock88
01-16-2003 05:07 PM
RedFirebird
07-09-2002 04:48 AM
Quick Reply: 1989 Rear Brakes - 1LE vs NON 1LE
Advertising
Featured Sponsors
Vendor Directory
Contact Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
