Booster bleeding off vacuum?
Old Nov 21, 2020 | 09:31 AM
theraymondguy's Avatar
Dialing in my carburetor, looking for potential vacuum leaks and testing individual components.
85 T/A, drum brakes.
When I apply vacuum directly to the brake booster it will pull to 18”Hg then stop, it will not go higher. It seems to be holding the applied vacuum.
Is this normal?
Rob
Old Nov 21, 2020 | 06:25 PM
NoEmissions84TA's Avatar
Re: Booster bleeding off vacuum?
Is this normal?
Rob
Yes, and the 90 degree barbed fitting going into the booster is actually a one-way check valve. If it's good, the booster should hold the vacuum.
mr z28
Brakes
Sep 23, 2014 03:34 PM
BlueZee28
Brakes
18
Jul 16, 2012 01:37 PM
husker2733
Oct 17, 2011 10:38 AM
pskel350
Sep 22, 2004 12:08 PM
chevyrumble83
Feb 18, 2004 08:10 AM
