Does removing the firewall padding require shimming the booster
Old Sep 5, 2024 | 10:48 PM
modracer's Avatar
Car: Morrison Cook #98 Iroc
Engine: L98 Corvette engine
Transmission: 5 speed
When removing the firewall padding between the brake pedal hanger assembly and firewall is the thickness enough that it requires the booster or master cylinder to be spaced a similar amount as technically it changes the rod position. Is the change enough that it would keep the brakes partially engaged or is there enough air space it wont matter.
Old Sep 6, 2024 | 07:22 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Does removing the firewall padding require shimming the booster
No. The padding shouldn't be in between, but none the less it doesn't require any spacing.
Old Sep 6, 2024 | 10:29 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Trim the pad around all the parts if needed. Use stock as template if you still have it.
Old Sep 6, 2024 | 10:45 AM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
My car doesn't have any there and is fine. No issues w the brakes.
Old Sep 7, 2024 | 09:30 PM
modracer's Avatar
This is on the Morrison Cook car. When I pulled the booster and pedal hangers from the firewall there was the firewall padding between the pedal hanger and firewall. I know on the old cars we use adjustable brake rods to put the needed air space but wasnt sure on a 3rd Gen.
Old Sep 8, 2024 | 08:07 AM
Car: 82 TA
The space there is insignificant, the brake pedal will likely be a couple of mm closer to you. If you think about it, your adding or removing material between the pedal mount and firewall and the swing of the pedal will compensate. What ever the leverage ratio is will determine the movement of the pedal. Every car I've pulled apart over the years has material sandwiched in there. Now my car doesn't have that material but a 4mm machined plate to stiffen the firewall. I'm sure if I measured the pedal distance it would be 1/2 inch closer to the floor but it's insignificant. As far are race car/period correctness, I have no idea. Personally, I'd rather not have it there.
rjcamel2355
Brakes
Mar 18, 2020 04:26 AM
'91CamaroRS
Brakes
Dec 26, 2015 06:44 PM
evilemokid94
Brakes
Apr 28, 2010 12:18 PM
redrummer
Brakes
Sep 28, 2006 12:34 AM
ElementsofSpeed
Jul 1, 2005 12:42 PM
