1987 Iroc-z High Performance
Car: 1987 5 speed Iroc-z
Engine: 305 TPI (not for long)
Transmission: 5 Speed
I have a 1987 Iroc-Z for sale. It is an original 5 speed hardtop 305 TPI car (until I got it) It has a red exterior and gray interior with Megan racing seats. I also installed the Matrix 4 point harnesses but original seats and belts will come with the car if desired. Like I said the car was just about all original in garage kept form when i got it. Ever since I have had it garage kept until I came to Michigan(only for a month). This summer I swapped the motor out with a 355 aluminum headed 10:1 motor. It has the 113 casting vette heads, hyper. pistons, turned crank and 30 overbore on the cylinders. The cam has about 540 lift (exact specs will be given with inquires) with 1.6 roller rockers.March underdrive polished aluminum pulley kit and new royal purple synthetic tranny fluid with a hurst shifter.I kept the motor fuel injected and used the holley stealth ram but when i started it up I realized the tune from PCMforless wasnt good enough. instead of going through mail order tuning i went all out and put a 100% closed loop DFI in the car. I have some connections and had Jobe tune the car. (best tuner on the east coast) The entire suspension setup is new with eibach lowering springs and sensitrac shocks all the way around. It has boxed rear control arms and an aftermarket panhard bar. Like I said almost everything is new on the car. Brand new fuel pump to handle the 26 lbs injectors. I am sure i am missing a lot so please call or drop me an email if you are interested. I have almost 20,000 in the car. The motor has been in for about 2 months now and only has 3000 or so miles on it. (800 is from NJ to Michigan trip and another couple 100 mile trips to Long Island to have it tuned and DFI installed) Almost all highway miles. The car has been to the track once with 6 easy passes on it. It ran a best of 13.5 at 106. The car will definitely run in the 12's. I am looking for 10,000 from the car obo. I am currently in northern Michigan but will be back in NJ soon so car can be seen in either location. My phone number is 201-312-5446 and my name is Matt
IROCZ2173@verizon.net
Re: 1987 Iroc-z High Performance
I would really prefer just a cash offer but i might entertain your trade offer. Make me an offer and we can talk.
Matt
201-312-5446
Matt
201-312-5446
Car: 2004 Silverado SS
Engine: 6.0L LQ9
Axle/Gears: 4.10 AWD
Hotrodboba400
12-10-2019 07:07 PM
TheTraut88
09-07-2015 05:22 PM
UltRoadWarrior9
09-02-2015 08:24 PM
