[NC] 1986 irocz custom
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Re: 1986 irocz custom
Mods and specs? What color are you painting it? What's the interior look like? More pics? Thanks.
Tks for reply.
I am in the process of documenting all build specs. Inside is perfect but I will send the specs and pictures in a few days.
Oren Summer
oren.summer@outlook.com
Oren Summer
Here are the specs for the entire car: Pictures coming in a few days.
Gen 1 350 with all new standard components; standard crank, rods, standard pistons, rings, bearings, and crank
New HOWARD'S SBC Chevy Retro-Fit Hyd. Roller 270/278 495"/500" 108° Camshaft Kit
New Proform 66906C Stamped Roller-Tip Rocker Arm 1.5 Ratio 3/8 in. Stud Clamshell
New Mighty Demon blow through 750
New Eldebrock polished intake manifold
New Elgin 1.94" Intake & 1.5" Exhaust Valve Set
New Felpro gaskets
New Electric water pump
New Melling high volume oil pump with pick up
New Acel HEI Dist.
New MSD 6al2 programmable ign
New Cloyes timing gear cover for roller cam
Ported and polished heads
New plug wires
New Holley 140 GPH electric fuel pump
New Holley 4-9 PSI adjustable fuel pump reg with return port, boost referenced
New Twin t-3/4 turbos
New MSD Tach converter box
Flowmaster Muffler, Big Block II 70 Series, 2 1/2 in. Inlet/2 1/2 in. Outlet, Steel, Aluminized
Corvette Fiberglass tail light panel and quad exhaust tips from C4
Custom dash and all new gauges including boost
New door and window rubber molding
Custom gear shifter for 700R4 transmission
Electronic wireless exhaust cut-outs on both sides
New oversize Tires
4 wheel disc brakes
New Front brakes
Posi-traction 3:08 rear
New Champion 3 row aluminum radiator
Driver’s seat to be recovered
New Felpro gaskets
New Acel HEI Dist.
New plug wires
New oversize Tires
4 wheel disc brakes
New Front brakes
